#include <OgreInertiaVisual.hh>
virtual ~OgreInertiaVisual ()
VisualPtr BoxVisual () const override
 Get the box visual. More...
void Load (const ignition::math::Pose3d &_pose, const ignition::math::Vector3d &_scale) override
- Public Member Functions inherited from BaseInertiaVisual< OgreVisual >
virtual ~BaseInertiaVisual ()
virtual void SetInertial (const ignition::math::Inertiald &_inertial) override
virtual ~InertiaVisual ()
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 Set material to line geometry. More...
- Protected Member Functions inherited from BaseInertiaVisual< OgreVisual >
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreInertiaVisual()
OgreInertiaVisual ( )
◆ ~OgreInertiaVisual()
virtual ~OgreInertiaVisual ( )
◆ BoxVisual()
VisualPtr BoxVisual ( ) const
Get the box visual.
Pointer to the box visual
Reimplemented from BaseInertiaVisual< OgreVisual >.
◆ Load()
void Load ( const ignition::math::Pose3d &  _pose,
const ignition::math::Vector3d &  _scale
Implements Visual.
◆ OgreObject()
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
