Map< T > Class Template Referenceabstract
#include <ignition/rendering/Storage.hh>
virtual ~Map ()
virtual bool ContainsKey (const std::string &_key) const =0
 Determine if an elements is mapped to the given key. More...
virtual bool ContainsValue (ConstTPtr _value) const =0
 Determine if the given element exists in this map. More...
virtual TPtr Get (const std::string &_key) const =0
 Get the element mapped to the given key. More...
 Get the element at the given index. More...
virtual bool Put (const std::string &_key, TPtr _value)=0
 Map to given element to the given key. If the given key is already in use, no work will be done. More...
virtual void Remove (const std::string &_key)=0
 Remove the element mapped to the given key. If the specified element does not exists, no work will be done. More...
virtual void Remove (TPtr _value)=0
 Remove the given element. If the given element does not exist no work will be done. More...
virtual void RemoveAll ()=0
 Remove all elements from this map. More...
 Get the number of elements in this map. More...
template<class T>
class ignition::rendering::Map< T >
Template Parameters
TThe storage element type
◆ ~Map()
virtual ~Map ( )
inlinevirtual
Deconstructor.
◆ ContainsKey()
virtual bool ContainsKey ( const std::string &  _key) const
[in]_keyKey of the element in question
True if an elements is mapped to the given key
Implemented in BaseMap< T, U >, and BaseMap< Material, T >.
◆ ContainsValue()
virtual bool ContainsValue ( ConstTPtr  _value) const
[in]_valueElement in question
True if the given element exists in this map
◆ Get()
virtual TPtr Get ( const std::string &  _key) const
The element mapped to the given key
◆ GetByIndex()
[in]_indexIndex of the element in question
The element at the given index
◆ Put()
virtual bool Put ( const std::string &  _key,
TPtr  _value
[in]_keyKey of the new element
[in]_valueElement to be mapped
True if successful
◆ Remove() [1/2]
virtual void Remove ( const std::string &  _key)
◆ Remove() [2/2]
virtual void Remove ( TPtr  _value)
[in]_valueKey of the element in question
◆ RemoveAll()
virtual void RemoveAll ( )
◆ Size()
The number of elements in this map
