Ogre 2.x implementation of the light class. More...
#include <Ogre2Light.hh>
virtual ~Ogre2Light ()
 Destroy the light. More...
virtual ~BaseLight ()
virtual ~Light ()
virtual ~Ogre2Node ()
 Ogre2Light ()
 Initialize the light. More...
 BaseLight ()
 Ogre2Node ()
 Set the parent node. More...
double attenConstant = 1.0
double attenLinear = 0.0
double attenQuadratic = 0.0
double attenRange = 100.0
 Attenuation range. More...
 Light type. More...
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Light()
Ogre2Light ( )
◆ ~Ogre2Light()
virtual ~Ogre2Light ( )
◆ AttenuationConstant()
Implements Light.
◆ AttenuationLinear()
The attenuation linear value
Implements Light.
◆ AttenuationQuadratic()
Implements Light.
◆ AttenuationRange()
The attenuation range
Implements Light.
◆ CastShadows()
Implements Light.
Destroy the light.
Reimplemented from Ogre2Node.
◆ DiffuseColor()
The diffuse color
Implements Light.
◆ Intensity()
virtual double Intensity ( ) const
The light intensity
Implements Light.
◆ Light()
virtual Ogre::Light* Light ( ) const
◆ SetAttenuationConstant()
Implements BaseLight< Ogre2Node >.
◆ SetAttenuationLinear()
◆ SetAttenuationQuadratic()
◆ SetAttenuationRange()
◆ SetCastShadows()
◆ SetDiffuseColor()
[in]_colorNew diffuse color
◆ SetIntensity()
virtual void SetIntensity ( double  _intensity)
[in]_intensityNew light intensity
Implements Light.
◆ SetSpecularColor()
[in]_colorNew specular color
◆ SpecularColor()
The specular color
Implements Light.
◆ attenConstant
◆ attenLinear
◆ attenQuadratic
◆ attenRange
Attenuation range.
◆ ogreLight
Ogre::Light* ogreLight = nullptr
◆ ogreLightType
Light type.
