MoveToHelper Class Reference
Helper class for animating a user camera to move to a target entity. More...
#include <MoveToHelper.hh>
 MoveToHelper ()
 ~MoveToHelper ()
void AddTime (double _time)
 Add time to the animation. More...
bool Idle () const
 Get whether the move to helper is idle, i.e. no animation is being executed. More...
void LookDirection (const rendering::CameraPtr &_camera, const math::Vector3d &_direction, const math::Vector3d &_lookAt, double _duration, std::function< void()> _onAnimationComplete)
 Move the camera to look at the specified target param[in] _camera Camera to be moved param[in] _direction The pose to assume relative to the entit(y/ies), (0, 0, 0) indicates to return the camera back to the home pose originally loaded in from the sdf. param[in] _duration Duration of the move to animation, in seconds. param[in] _onAnimationComplete Callback function when animation is complete. More...
void MoveTo (const rendering::CameraPtr &_camera, const math::Pose3d &_target, double _duration, std::function< void()> _onAnimationComplete)
 Move the camera to the specified pose. param[in] _camera Camera to be moved param[in] _target Pose to move to param[in] _duration Duration of the move to animation, in seconds. param[in] _onAnimationComplete Callback function when animation is complete. More...
void MoveTo (const rendering::CameraPtr &_camera, const rendering::NodePtr &_target, double _duration, std::function< void()> _onAnimationComplete)
 Move the camera to look at the specified target param[in] _camera Camera to be moved param[in] _target Target to look at param[in] _duration Duration of the move to animation, in seconds. param[in] _onAnimationComplete Callback function when animation is complete. More...
void SetInitCameraPose (const math::Pose3d &_pose)
 Set the initial camera pose param[in] _pose The init pose of the camera. More...
◆ MoveToHelper()
◆ ~MoveToHelper()
◆ AddTime()
void AddTime ( double  _time)
[in]_timeTime to add in seconds
◆ Idle()
bool Idle ( ) const
True if idle, false otherwise
◆ LookDirection()
void LookDirection ( const rendering::CameraPtr &  _camera,
const math::Vector3d &  _direction,
const math::Vector3d &  _lookAt,
double  _duration,
◆ MoveTo() [1/2]
void MoveTo ( const rendering::CameraPtr &  _camera,
const math::Pose3d &  _target,
double  _duration,
◆ MoveTo() [2/2]
const rendering::NodePtr &  _target,
double  _duration,
◆ SetInitCameraPose()
void SetInitCameraPose ( const math::Pose3d &  _pose)
References IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING, and IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING.
