BaseLightStore< T > Class Template Reference
#include <BaseStorage.hh>
- Public Member Functions inherited from BaseStore< Light, T >
 BaseStore ()
virtual ~BaseStore ()
virtual UIter Begin ()
virtual void DestroyAll ()
virtual UIter End ()
virtual void RemoveAll ()
virtual ~Store ()
- Protected Member Functions inherited from BaseStore< Light, T >
- Protected Attributes inherited from BaseStore< Light, T >
UStore store
