#include <OgreLight.hh>
virtual ~OgreSpotLight ()
virtual math::Vector3d Direction () const
virtual double Falloff () const
virtual math::Angle InnerAngle () const
virtual math::Angle OuterAngle () const
virtual void SetDirection (const math::Vector3d &_dir)
virtual void SetFalloff (double _falloff)
virtual void SetInnerAngle (const math::Angle &_angle)
virtual void SetOuterAngle (const math::Angle &_angle)
- Public Member Functions inherited from BaseSpotLight< OgreLight >
virtual ~BaseSpotLight ()
virtual ~SpotLight ()
virtual ~Light ()
virtual ~OgreLight ()
virtual ~BaseLight ()
virtual ~OgreNode ()
 OgreSpotLight ()
- Protected Member Functions inherited from BaseSpotLight< OgreLight >
 BaseSpotLight ()
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreSpotLight()
OgreSpotLight ( )
◆ ~OgreSpotLight()
virtual ~OgreSpotLight ( )
◆ Direction()
The direction of the light
Implements SpotLight.
◆ Falloff()
The falloff of the spotlight
◆ InnerAngle()
◆ OuterAngle()
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseSpotLight< OgreLight >.
◆ SetFalloff()
◆ SetInnerAngle()
◆ SetOuterAngle()
