SpotLight Class Referenceabstract
virtual ~SpotLight ()
virtual void SetInnerAngle (double _radians)=0
virtual void SetOuterAngle (double _radians)=0
virtual ~Light ()
◆ ~SpotLight()
virtual ~SpotLight ( )
inlinevirtual
Deconstructor.
◆ Direction()
The direction of the light
◆ Falloff()
The falloff of the spotlight
◆ InnerAngle()
◆ OuterAngle()
◆ SetDirection() [1/2]
[in]_dirNew direction vector
Implemented in BaseSpotLight< T >, BaseSpotLight< Ogre2Light >, BaseSpotLight< OgreLight >, Ogre2SpotLight, and OgreSpotLight.
◆ SetDirection() [2/2]
double  _y,
double  _z
Implemented in BaseSpotLight< T >, BaseSpotLight< Ogre2Light >, and BaseSpotLight< OgreLight >.
◆ SetFalloff()
◆ SetInnerAngle() [1/2]
◆ SetInnerAngle() [2/2]
virtual void SetInnerAngle ( double  _radians)
◆ SetOuterAngle() [1/2]
◆ SetOuterAngle() [2/2]
virtual void SetOuterAngle ( double  _radians)
