BaseSpotLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
virtual ~BaseSpotLight ()
virtual ~SpotLight ()
virtual ~Light ()
 BaseSpotLight ()
◆ BaseSpotLight()
BaseSpotLight
◆ ~BaseSpotLight()
~BaseSpotLight
◆ Reset()
void Reset
References IGN_PI.
◆ SetDirection() [1/2]
[in]_dirNew direction vector
Implements SpotLight.
◆ SetDirection() [2/2]
void SetDirection ( double  _x,
double  _y,
double  _z
◆ SetFalloff()
◆ SetInnerAngle() [1/2]
◆ SetInnerAngle() [2/2]
void SetInnerAngle ( double  _radians)
◆ SetOuterAngle() [1/2]
◆ SetOuterAngle() [2/2]
void SetOuterAngle ( double  _radians)
