GaussianNoisePass Class Referenceabstract
#include <GaussianNoisePass.hh>
 GaussianNoisePass ()
virtual ~GaussianNoisePass ()
virtual double Bias () const =0
 Accessor for bias. More...
virtual double Mean () const =0
 Accessor for mean. More...
virtual void SetBiasMean (double _biasMean)=0
 Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
virtual void SetBiasStdDev (double _biasStdDev)=0
 Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
virtual void SetMean (double _mean)=0
 Set mean. More...
virtual void SetStdDev (double _stdDev)=0
 Set stddev. More...
virtual double StdDev () const =0
 Accessor for stddev. More...
virtual ~RenderPass ()
◆ GaussianNoisePass()
◆ ~GaussianNoisePass()
virtual ~GaussianNoisePass ( )
◆ Bias()
virtual double Bias ( ) const
◆ Mean()
virtual double Mean ( ) const
Accessor for mean.
Mean of Gaussian noise.
Implemented in BaseGaussianNoisePass< T >, BaseGaussianNoisePass< OgreRenderPass >, and BaseGaussianNoisePass< Ogre2RenderPass >.
◆ SetBiasMean()
virtual void SetBiasMean ( double  _biasMean)
SetBiasStdDev
◆ SetBiasStdDev()
virtual void SetBiasStdDev ( double  _biasStdDev)
SetBiasMean
◆ SetMean()
virtual void SetMean ( double  _mean)
Set mean.
[in]_meanMean of Gaussian noise.
◆ SetStdDev()
virtual void SetStdDev ( double  _stdDev)
Set stddev.
[in]_stdDevStandard deviation of Gaussian noise.
◆ StdDev()
virtual double StdDev ( ) const
