RenderPass Class Referenceabstract
#include <ignition/rendering/RenderPass.hh>
virtual ~RenderPass ()
◆ ~RenderPass()
virtual ~RenderPass ( )
inlinevirtual
◆ IsEnabled()
True if the render pass is enabled, false otherwise.
Implemented in BaseRenderPass< T >, BaseRenderPass< Ogre2Object >, and BaseRenderPass< OgreObject >.
◆ SetEnabled()
[in]_enabledTrue to enable the render pass, false to disable.
