Base render pass that can be applied to a render target. More...
#include <BaseRenderPass.hh>
virtual ~BaseRenderPass ()
virtual ~RenderPass ()
 BaseRenderPass ()
bool enabled = true
template<class T>
class ignition::rendering::BaseRenderPass< T >
◆ BaseRenderPass()
BaseRenderPass
◆ ~BaseRenderPass()
~BaseRenderPass
◆ IsEnabled()
bool IsEnabled ( ) const
True if the render pass is enabled, false otherwise.
Implements RenderPass.
◆ SetEnabled()
void SetEnabled ( bool  _enabled)
[in]_enabledTrue to enable the render pass, false to disable.
◆ enabled
bool enabled = true
