BaseGaussianNoisePass< T > Class Template Reference
Base Gaussian noise render pass. More...
#include <BaseGaussianNoisePass.hh>
virtual ~BaseGaussianNoisePass ()
double Bias () const
 Accessor for bias. More...
double Mean () const
 Accessor for mean. More...
void SetBiasMean (double _biasMean)
 Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
void SetBiasStdDev (double _biasStdDev)
 Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
void SetMean (double _mean)
 Set mean. More...
void SetStdDev (double _stdDev)
 Set stddev. More...
double StdDev () const
 Accessor for stddev. More...
- Public Member Functions inherited from GaussianNoisePass
virtual ~GaussianNoisePass ()
virtual ~RenderPass ()
void SampleBias ()
double bias = 0.0
 Gaussian noise bias. More...
double biasMean = 0
 The mean of the Gaussian distribution from which bias values are drawn. More...
double biasStdDev = 0
 The standard deviation of the Gaussian distribution from which bias values are drawn. More...
double mean = 0.0
 Gaussian noise mean. More...
double stdDev = 0.0
 Standard deviation of Gaussian noise. More...
template<class T>
class ignition::rendering::BaseGaussianNoisePass< T >
◆ BaseGaussianNoisePass()
◆ ~BaseGaussianNoisePass()
◆ Bias()
double Bias ( ) const
Accessor for bias.
Bias on output.
Implements GaussianNoisePass.
◆ Mean()
double Mean ( ) const
Accessor for mean.
Mean of Gaussian noise.
References mean().
◆ SampleBias()
void SampleBias
◆ SetBiasMean()
void SetBiasMean ( double  _biasMean)
SetBiasStdDev
◆ SetBiasStdDev()
void SetBiasStdDev ( double  _biasStdDev)
SetBiasMean
◆ SetMean()
void SetMean ( double  _mean)
Set mean.
[in]_meanMean of Gaussian noise.
References mean().
◆ SetStdDev()
void SetStdDev ( double  _stdDev)
Set stddev.
[in]_stdDevStandard deviation of Gaussian noise.
◆ StdDev()
double StdDev ( ) const
◆ bias
double bias = 0.0
◆ biasMean
double biasMean = 0
◆ biasStdDev
◆ mean
double mean = 0.0
◆ stdDev
double stdDev = 0.0
