BaseSegmentationCamera< T > Class Template Referenceabstract
#include <BaseSegmentationCamera.hh>
virtual ~BaseSegmentationCamera ()
virtual const math::Color & BackgroundColor () const override
 Get color for background & unlabeled items in the colored map. More...
virtual int BackgroundLabel () const override
 Get label for background & unlabeled items in the semantic map. More...
virtual ignition::common::ConnectionPtr ConnectNewSegmentationFrame (std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect to the new Segmentation image event. More...
virtual void CreateSegmentationTexture () override=0
 Create a texture which will hold the segmentation data. More...
virtual void EnableColoredMap (bool _enable) override
 Enable Color map mode to generate colored semantics. More...
virtual bool IsColoredMap () const override
 Check if color map mode is enabled. More...
void LabelMapFromColoredBuffer (uint8_t *_labelBuffer) const override=0
 Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored map and the corresponding IDs map. This function must be called before the next render loop and the colored map mode must be enabeled. More...
virtual uint8_t * SegmentationData () const override
 Get the segmentation image data. If the segmentation type is panoptic, the first two channels are the instance count, and the last channel is the label. More...
virtual void SetBackgroundColor (const math::Color &_color) override
 Set color for background & unlabeled items in the colored map. More...
virtual void SetBackgroundLabel (int _label) override
 Set label for background & unlabeled items in the semantic map. More...
virtual void SetSegmentationType (SegmentationType _type) override
 Set Segmentation Type. More...
virtual SegmentationType Type () const override
 Get Segmentation Type. More...
- Public Member Functions inherited from SegmentationCamera
virtual ~SegmentationCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
virtual ~BaseCamera ()
 BaseCamera ()
math::Color backgroundColor {0, 0, 0}
 The color of objects that are considered background (i.e., objects that have no label) More...
int backgroundLabel {0}
 The label of background objects. More...
bool isColoredMap {false}
 Whether a colored map is being generated (true) or label ID map is being generated (false) More...
uint8_t * segmentationData {nullptr}
 The buffer that contains segmentation data. More...
SegmentationType type {SegmentationType::ST_SEMANTIC}
 The segmentation type. More...
 Anti-aliasing. More...
double aspect = 1.3333333
 Aspect ratio. More...
double farClip = 1000.0
NodePtr followNode
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseSegmentationCamera()
◆ ~BaseSegmentationCamera()
◆ BackgroundColor()
const math::Color & BackgroundColor ( ) const
Color of background & unlabeled items
Implements SegmentationCamera.
◆ BackgroundLabel()
int BackgroundLabel ( ) const
label of background & unlabeled items
◆ ConnectNewSegmentationFrame()
ignition::common::ConnectionPtr ConnectNewSegmentationFrame ( std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
[in]_subscriberSubscriber callback function. The callback function arguments are: <segmentation data, width, height, channels, format>
Reimplemented in Ogre2SegmentationCamera.
◆ CreateSegmentationTexture()
virtual void CreateSegmentationTexture ( )
overridepure virtual
Implemented in Ogre2SegmentationCamera.
◆ EnableColoredMap()
void EnableColoredMap ( bool  _enable)
[in]_enableTrue to generate colored map, False to generate label id map
◆ IsColoredMap()
bool IsColoredMap ( ) const
True if colored map, False if label id map
◆ LabelMapFromColoredBuffer()
void LabelMapFromColoredBuffer ( uint8_t *  _labelBuffer) const
[out]_labelBufferA buffer that is populated with the label IDs map data. This output buffer must be allocated with the same size before calling
◆ SegmentationData()
uint8_t * SegmentationData ( ) const
The labels-buffer as an array of unsigned ints
◆ SetBackgroundColor()
void SetBackgroundColor ( const math::Color &  _color)
[in]_colorColor of background & unlabeled items
◆ SetBackgroundLabel()
void SetBackgroundLabel ( int  _label)
[in]_labellabel of background & unlabeled items
◆ SetSegmentationType()
void SetSegmentationType ( SegmentationType  _type)
[in]_typeSegmentation Type
◆ Type()
SegmentationType Type ( ) const
Segmentation Type
◆ backgroundColor
◆ backgroundLabel
◆ isColoredMap
◆ segmentationData
uint8_t* segmentationData {nullptr}
◆ type
