Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce segmentation data, instead of a 2D image. More...
#include <SegmentationCamera.hh>
| virtual | ~SegmentationCamera () |
| Destructor. More... | |
| virtual const math::Color & | BackgroundColor () const =0 |
| Get color for background & unlabeled items in the colored map. More... | |
| virtual int | BackgroundLabel () const =0 |
| Get label for background & unlabeled items in the semantic map. More... | |
| virtual ignition::common::ConnectionPtr | ConnectNewSegmentationFrame (std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0 |
| Connect to the new Segmentation image event. More... | |
| virtual void | CreateSegmentationTexture ()=0 |
| Create a texture which will hold the segmentation data. More... | |
| virtual void | EnableColoredMap (bool _enable)=0 |
| Enable Color map mode to generate colored semantics. More... | |
| virtual bool | IsColoredMap () const =0 |
| Check if color map mode is enabled. More... | |
| virtual void | LabelMapFromColoredBuffer (uint8_t *_labelBuffer) const =0 |
| Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored map and the corresponding IDs map. This function must be called before the next render loop and the colored map mode must be enabeled. More... | |
| virtual uint8_t * | SegmentationData () const =0 |
| Get the segmentation image data. If the segmentation type is panoptic, the first two channels are the instance count, and the last channel is the label. More... | |
| virtual void | SetBackgroundColor (const math::Color &_color)=0 |
| Set color for background & unlabeled items in the colored map. More... | |
| virtual void | SetBackgroundLabel (int _label)=0 |
| Set label for background & unlabeled items in the semantic map. More... | |
| virtual void | SetSegmentationType (SegmentationType _type)=0 |
| Set Segmentation Type. More... | |
| virtual SegmentationType | Type () const =0 |
| Get Segmentation Type. More... | |
| virtual | ~Camera () |
| Deconstructor. More... | |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns. More... | |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
◆ ~SegmentationCamera()
inlinevirtual |
◆ BackgroundColor()
pure virtual |
- Returns
- Color of background & unlabeled items
Implemented in BaseSegmentationCamera< T >, and BaseSegmentationCamera< Ogre2Sensor >.
◆ BackgroundLabel()
pure virtual |
- Returns
- label of background & unlabeled items
◆ ConnectNewSegmentationFrame()
pure virtual |
[in] _subscriber Subscriber callback function. The callback function arguments are: <segmentation data, width, height, channels, format>
- Returns
Implemented in Ogre2SegmentationCamera, BaseSegmentationCamera< T >, and BaseSegmentationCamera< Ogre2Sensor >.
◆ CreateSegmentationTexture()
pure virtual |
Implemented in BaseSegmentationCamera< T >, BaseSegmentationCamera< Ogre2Sensor >, and Ogre2SegmentationCamera.
◆ EnableColoredMap()
pure virtual |
[in] _enable True to generate colored map, False to generate label id map
◆ IsColoredMap()
pure virtual |
- Returns
- True if colored map, False if label id map
◆ LabelMapFromColoredBuffer()
pure virtual |
[out] _labelBuffer A buffer that is populated with the label IDs map data. This output buffer must be allocated with the same size before calling
◆ SegmentationData()
pure virtual |
- Returns
- The labels-buffer as an array of unsigned ints
◆ SetBackgroundColor()
pure virtual |
[in] _color Color of background & unlabeled items
◆ SetBackgroundLabel()
pure virtual |
[in] _label label of background & unlabeled items
◆ SetSegmentationType()
pure virtual |
[in] _type Segmentation Type
◆ Type()
pure virtual |
- Returns
- Segmentation Type
