ParticleEmitter Class Referenceabstract
#include <ParticleEmitter.hh>
virtual ~ParticleEmitter ()
virtual ignition::math::Color ColorEnd () const =0
 Get the end color of the particles. More...
virtual std::string ColorRangeImage () const =0
 Get the path to the color image used as an affector. More...
virtual ignition::math::Color ColorStart () const =0
 Get the starting color of the particles. More...
virtual double Duration () const =0
 Get the number of seconds the emitter is active. A value of 0 means infinite duration. More...
virtual ignition::math::Vector3d EmitterSize () const =0
 Get the size of the emitter where the particles are sampled. More...
virtual bool Emitting () const =0
 Is the particle emitter enabled? More...
virtual double Lifetime () const =0
 Get the number of seconds each particle will ’live’ for before being destroyed. More...
 Get the material which all particles in the emitter will use. More...
virtual double MaxVelocity () const =0
 Get the maximum velocity each particle is emitted (m/s). More...
virtual double MinVelocity () const =0
 Get the minimum velocity each particle is emitted (m/s). More...
virtual float ParticleScatterRatio () const =0
 Get the particle scatter ratio. More...
virtual ignition::math::Vector3d ParticleSize () const =0
 Get the particle dimensions (width, height, depth). More...
virtual double Rate () const =0
 Get how many particles per second should be emitted. More...
virtual double ScaleRate () const =0
 Get the amount by which to scale the particles in both x and y direction per second. Default value is 1. More...
virtual void SetColorRange (const ignition::math::Color &_colorStart, const ignition::math::Color &_colorEnd)=0
 Sets a color for all particle emitted. The actual color will be interpolated between these two colors Color::White is the default color for the particles unless a specific function is used. Note that this function overrides the particle colors set with SetColorRangeImage(). More...
virtual void SetColorRangeImage (const std::string &_image)=0
 Set the path to the color image used as an affector. This affector modifies the color of particles in flight. The colors are taken from a specified image file. The range of color values begins from the left side of the image and move to the right over the lifetime of the particle, therefore only the horizontal dimension of the image is used. Note that this function overrides the particle colors set with SetColorRange(). More...
virtual void SetDuration (double _duration)=0
 Set the number of seconds the emitter is active. A value of 0 means infinite duration. Default value is 0. More...
virtual void SetEmitterSize (const ignition::math::Vector3d &_size)=0
 Set the size of the emitter where the particles are sampled. Default value is (1, 1, 1). Note that the interpretation of the emitter area varies depending on the emmiter type: More...
virtual void SetEmitting (bool _enable)=0
 This is used to turn on or off particle emission. Default value is false. More...
virtual void SetLifetime (double _lifetime)=0
 Set the number of seconds each particle will ’live’ for before being destroyed. Default value is 5. More...
 Sets the material which all particles in the emitter will use. More...
virtual void SetParticleScatterRatio (float _ratio)=0
 Set the particle scatter ratio. More...
virtual void SetParticleSize (const ignition::math::Vector3d &_size)=0
 Set the particle dimensions (width, height, depth). Default value is {1, 1, 1}. More...
virtual void SetRate (double _rate)=0
 Set how many particles per second should be emitted. Default value is 10. More...
virtual void SetScaleRate (double _scaleRate)=0
 Set the amount by which to scale the particles in both x and y direction per second. More...
virtual void SetType (const EmitterType _type)=0
 Set the emitter type. Default value is EM_POINT. More...
virtual void SetVelocityRange (double _minVelocity, double _maxVelocity)=0
 Set a velocity range and each particle is emitted with a random velocity within this range (m/s). Default value is 1 for both velocities. More...
virtual EmitterType Type () const =0
 Get the emitter type. More...
ignition/rendering/ParticleEmitter.hh
◆ ~ParticleEmitter()
virtual ~ParticleEmitter ( )
inlinevirtual
◆ ColorEnd()
virtual ignition::math::Color ColorEnd ( ) const
End color.
ColorStart
SetColorRange
Implemented in BaseParticleEmitter< T >, BaseParticleEmitter< OgreVisual >, and BaseParticleEmitter< Ogre2Visual >.
◆ ColorRangeImage()
virtual std::string ColorRangeImage ( ) const
The color image name or empty string if the image is not set.
SetColorRangeImage
◆ ColorStart()
virtual ignition::math::Color ColorStart ( ) const
Start color.
ColorEnd
SetColorRange
◆ Duration()
virtual double Duration ( ) const
Total duration of the emitter (seconds).
SetDuration
◆ EmitterSize()
virtual ignition::math::Vector3d EmitterSize ( ) const
The emitter size. See SetEmitterSize() for the interpretation of the dimensions depending on the emitter type.
SetEmitterSize
◆ Emitting()
virtual bool Emitting ( ) const
True when enabled or false otherwise.
SetEmitting
◆ Lifetime()
virtual double Lifetime ( ) const
Lifetime of each particle (seconds).
SetLifetime
The material pointer.
SetMaterial
Implements Visual.
◆ MaxVelocity()
virtual double MaxVelocity ( ) const
Maximum velocity.
MinVelocity
SetVelocityRange
◆ MinVelocity()
virtual double MinVelocity ( ) const
Minimum velocity.
MaxVelocity
SetVelocityRange
◆ ParticleScatterRatio()
virtual float ParticleScatterRatio ( ) const
The particle scatter ratio.
◆ ParticleSize()
virtual ignition::math::Vector3d ParticleSize ( ) const
Particle dimensions.
SetParticleSize
◆ Rate()
virtual double Rate ( ) const
Particles per second.
SetRate
◆ ScaleRate()
virtual double ScaleRate ( ) const
The scale rate.
SetScaleRate
◆ SetColorRange()
virtual void SetColorRange ( const ignition::math::Color &  _colorStart,
const ignition::math::Color &  _colorEnd
[in]_colorStartStart color.
[in]_colorEndEnd color.
ColorStart
ColorEnd
Implemented in Ogre2ParticleEmitter, BaseParticleEmitter< T >, BaseParticleEmitter< OgreVisual >, and BaseParticleEmitter< Ogre2Visual >.
◆ SetColorRangeImage()
virtual void SetColorRangeImage ( const std::string &  _image)
[in]_imageThe color image name.
ColorRangeImage
◆ SetDuration()
virtual void SetDuration ( double  _duration)
[in]_durationTotal duration of the emitter (seconds).
Duration
◆ SetEmitterSize()
virtual void SetEmitterSize ( const ignition::math::Vector3d &  _size)
  • EM_POINT: The area is ignored.
  • EM_BOX: The area is interpreted as width X height X depth.
  • EM_CYLINDER: The area is interpreted as the bounding box of the cilinder. The cylinder is oriented along the Z-axis.
  • EM_ELLIPSOID: The area is interpreted as the bounding box of an ellipsoid shaped area, i.e. a sphere or squashed-sphere area. The parameters are again identical to EM_BOX, except that the dimensions describe the widest points along each of the axes.
    [in]_sizeSize of the emitter (width, height, depth).
    EmitterSize
◆ SetEmitting()
virtual void SetEmitting ( bool  _enable)
[in]_enableTrue for enabling the emission or false otherwise.
Emitting
◆ SetLifetime()
virtual void SetLifetime ( double  _lifetime)
[in]_lifetimeLifetime of each particle (seconds).
Lifetime
◆ SetMaterial()
[in]_materialThe material pointer.
Material
◆ SetParticleScatterRatio()
virtual void SetParticleScatterRatio ( float  _ratio)
[in]_ratioThe scatter ratio. The particle emitter's scatter ratio will only be set to _ratio if _ratio > 0.
◆ SetParticleSize()
virtual void SetParticleSize ( const ignition::math::Vector3d &  _size)
[in]_sizeParticle dimensions.
ParticleSize
◆ SetRate()
virtual void SetRate ( double  _rate)
[in]_rateParticles per second.
Rate
◆ SetScaleRate()
virtual void SetScaleRate ( double  _scaleRate)
[in]_scaleRateThe scale rate.
ScaleRate
◆ SetType()
virtual void SetType ( const EmitterType  _type)
[in]_typeEmitter type.
EmitterType.
Type.
◆ SetVelocityRange()
virtual void SetVelocityRange ( double  _minVelocity,
double  _maxVelocity
[in]_minVelocityMinimum velocity.
[in]_maxVelocityMaximum velocity.
MinVelocity
MaxVelocity
◆ Type()
virtual EmitterType Type ( ) const
Emitter type.
EmitterType.
SetType.
