BaseDistortionPass< T > Class Template Reference
Base distortion render pass. More...
#include <BaseDistortionPass.hh>
virtual ~BaseDistortionPass ()
math::Vector2d Center () const
 Get the distortion center. More...
double K1 () const
 Get the radial distortion coefficient k1. More...
double K2 () const
 Get the radial distortion coefficient k2. More...
double K3 () const
 Get the radial distortion coefficient k3. More...
double P1 () const
 Get the tangential distortion coefficient p1. More...
double P2 () const
 Get the tangential distortion coefficient p2. More...
void SetCenter (const math::Vector2d &_center)
 Set the distortion center. More...
void SetK1 (double _k1)
 Set the radial distortion coefficient k1. More...
void SetK2 (double _k2)
 Set the radial distortion coefficient k2. More...
void SetK3 (double _k3)
 Set the radial distortion coefficient k3. More...
void SetP1 (double _p1)
 Set the tangential distortion coefficient p1. More...
void SetP2 (double _p2)
 Set the tangential distortion coefficient p2. More...
- Public Member Functions inherited from DistortionPass
 DistortionPass ()
virtual ~DistortionPass ()
virtual ~RenderPass ()
Public Attributes
double k1 = 0
 Radial distortion coefficient k1. More...
double k2 = 0
 Radial distortion coefficient k2. More...
double k3 = 0
 Radial distortion coefficient k3. More...
math::Vector2d lensCenter = {0.5, 0.5}
 Lens center used for distortion. More...
double p1 = 0
 Tangential distortion coefficient p1. More...
double p2 = 0
 Tangential distortion coefficient p2. More...
template<class T>
class ignition::rendering::BaseDistortionPass< T >
◆ BaseDistortionPass()
BaseDistortionPass
◆ ~BaseDistortionPass()
◆ Center()
math::Vector2d Center ( ) const
Distortion center.
Implements DistortionPass.
◆ K1()
double K1 ( ) const
Distortion coefficient k1.
◆ K2()
double K2 ( ) const
Distortion coefficient k2.
◆ K3()
double K3 ( ) const
Distortion coefficient k3.
◆ P1()
double P1 ( ) const
Distortion coefficient p1.
◆ P2()
double P2 ( ) const
Distortion coefficient p2.
◆ SetCenter()
void SetCenter ( const math::Vector2d &  _center)
[in]_centerDistortion center.
◆ SetK1()
void SetK1 ( double  _k1)
[in]_k1Distortion coefficient k1.
◆ SetK2()
void SetK2 ( double  _k2)
[in]_k2Distortion coefficient k1.
◆ SetK3()
void SetK3 ( double  _k3)
[in]_k3Distortion coefficient k1.
◆ SetP1()
void SetP1 ( double  _p1)
[in]_p1Distortion coefficient k1.
◆ SetP2()
void SetP2 ( double  _p2)
[in]_p2Distortion coefficient k1.
◆ k1
double k1 = 0
◆ k2
double k2 = 0
◆ k3
double k3 = 0
◆ lensCenter
◆ p1
double p1 = 0
◆ p2
double p2 = 0
