BaseBoundingBoxCamera< T > Class Template Referenceabstract
#include <BaseBoundingBoxCamera.hh>
| virtual | ~BaseBoundingBoxCamera () |
| Destructor. More... | |
| virtual const std::vector< BoundingBox > & | BoundingBoxData () const |
| Get the BoundingBox data. More... | |
| virtual ignition::common::ConnectionPtr | ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)> _subscriber)=0 |
| Connect to the new BoundingBox info. More... | |
| virtual void | DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const =0 |
| Draw a bounding box on the given image. More... | |
| virtual void | SetBoundingBoxType (BoundingBoxType _type) |
| Set BoundingBox Type (Visible / Full) More... | |
| virtual BoundingBoxType | Type () const |
| Get the BoundingBox Type (Visible / Full) More... | |
Public Member Functions inherited from BoundingBoxCamera | |
| virtual | ~BoundingBoxCamera () |
| virtual | ~Camera () |
| Deconstructor. More... | |
| Writes the last rendered image into a caller owned buffer, for example a message payload, without an intermediate copy. Like Copy, this can be called any number of times after PostRender. The buffer must match the camera's image size and be at least _buffer.MemorySize() bytes. Nothing keeps a pointer to the buffer once this call returns. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
Public Member Functions inherited from BaseCamera< T > | |
| virtual | ~BaseCamera () |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| BaseBoundingBoxCamera () | |
| Constructor. More... | |
Protected Member Functions inherited from BaseCamera< T > | |
| BaseCamera () | |
| virtual void * | CreateImageBuffer () const |
| virtual void | Load () override |
| virtual RenderTargetPtr | RenderTarget () const =0 |
| virtual void | Reset () |
Protected Attributes | |
| std::vector< BoundingBox > | boundingBoxes |
| The bounding box data. More... | |
| BoundingBoxType | type = BoundingBoxType::BBT_FULLBOX2D |
| The bounding box type. More... | |
Protected Attributes inherited from BaseCamera< T > | |
| unsigned int | antiAliasing = 0u |
| Anti-aliasing. More... | |
| double | aspect = 1.3333333 |
| Aspect ratio. More... | |
| double | farClip = 1000.0 |
| Far clipping plane distance. More... | |
| NodePtr | followNode |
| Target node to follow. More... | |
| math::Vector3d | followOffset |
| Offset distance between camera and target node being followed. More... | |
| double | followPGain = 1.0 |
| P gain for follow mode. Determines how fast the camera moves to follow the target node. Valid range: [0-1]. More... | |
| bool | followWorldFrame = false |
| Follow target in world frame. More... | |
| math::Angle | hfov |
| Horizontal camera field of view. More... | |
| ImagePtr | imageBuffer |
| double | nearClip = 0.01 |
| Near clipping plane distance. More... | |
| common::EventT< void(const void *, unsigned int, unsigned int, unsigned int, const std::string &)> | newFrameEvent |
| math::Matrix4d | projectionMatrix |
| Custom projection matrix. More... | |
| CameraProjectionType | projectionType = CPT_PERSPECTIVE |
| Camera projection type. More... | |
| NodePtr | trackNode |
| Target node to track if camera tracking is on. More... | |
| math::Vector3d | trackOffset |
| Set camera to track a point offset in target node's local or world frame depending on trackWorldFrame. More... | |
| double | trackPGain = 1.0 |
| P gain for tracking. Determines how fast the camera rotates to look at the target node. Valid range: [0-1]. More... | |
| bool | trackWorldFrame = false |
| Track point relative to target in world frame. More... | |
◆ BaseBoundingBoxCamera()
protected |
◆ ~BaseBoundingBoxCamera()
virtual |
◆ BoundingBoxData()
virtual |
- Returns
- Buffer of bounding boxes info (label, minX, minY, maxX, maxY). If the camera's bounding box type is 3D, minZ and maxZ are also defined)
Implements BoundingBoxCamera.
Reimplemented in Ogre2BoundingBoxCamera.
◆ ConnectNewBoundingBoxes()
pure virtual |
[in] _subscriber Subscriber callback function
- Returns
Implemented in Ogre2BoundingBoxCamera.
◆ DrawBoundingBox()
pure virtual |
[in] _data buffer containing the image data [in] _color Color of the bounding box to be drawn [in] _box bounding box to be drawn
◆ SetBoundingBoxType()
virtual |
[in] _type BoundingBox Type (Visible / Full)
◆ Type()
virtual |
- Returns
- BoundingBox Type (Visible / Full)
◆ boundingBoxes
protected |
◆ type
protected |
