AxisVisual Class Referenceabstract
Represents a axis composite visual. More...
#include <ignition/rendering/AxisVisual.hh>
virtual ~AxisVisual ()
virtual void ShowAxisHead (bool _b)=0
 set true to show the axis heads, false otherwise More...
virtual void ShowAxisHead (unsigned int _axis, bool _b)=0
 set true to show the specified axis head, false otherwise More...
virtual ~CompositeVisual ()
◆ ~AxisVisual()
virtual ~AxisVisual ( )
inlinevirtual
Deconstructor.
◆ ShowAxisHead() [1/2]
virtual void ShowAxisHead ( bool  _b)
[in]_btrue to show the axis heads, false otherwise
Implemented in BaseAxisVisual< T >, BaseAxisVisual< OgreVisual >, and BaseAxisVisual< Ogre2Visual >.
◆ ShowAxisHead() [2/2]
virtual void ShowAxisHead ( unsigned int  _axis,
bool  _b
[in]_axisAxis index. 0: x, 1: y, 2: z
[in]_btrue to show the specified axis head, false otherwise
