CompositeVisual Class Reference
Represents a predefined collection of geometries and visuals. More...
#include <CompositeVisual.hh>
virtual ~CompositeVisual ()
ignition/rendering/CompositeVisual.hh
◆ ~CompositeVisual()
virtual ~CompositeVisual ( )
inlinevirtual
Deconstructor.
