HeightmapTexture Class Reference
Texture to be used on heightmaps. More...
#include <HeightmapDescriptor.hh>
 HeightmapTexture ()
 HeightmapTexture (const HeightmapTexture &_texture)
 Copy constructor. More...
 HeightmapTexture (HeightmapTexture &&_texture) noexcept
 Move constructor. More...
virtual ~HeightmapTexture ()
std::string Diffuse () const
 Get the heightmap texture's diffuse map. More...
std::string Normal () const
 Get the heightmap texture's normal map. More...
HeightmapTexture & operator= (const HeightmapTexture &_texture)
 Copy Assignment operator. More...
HeightmapTexture & operator= (HeightmapTexture &&_texture)
 Move assignment operator. More...
void SetDiffuse (const std::string &_diffuse)
 Set the filename of the diffuse map. More...
void SetNormal (const std::string &_normal)
 Set the filename of the normal map. More...
void SetSize (double _size)
 Set the size of the texture in meters. More...
double Size () const
 Get the heightmap texture's size. More...
◆ HeightmapTexture() [1/3]
◆ HeightmapTexture() [2/3]
HeightmapTexture ( const HeightmapTexture &  _texture)
Copy constructor.
[in]_textureHeightmapTexture to copy.
◆ HeightmapTexture() [3/3]
HeightmapTexture ( HeightmapTexture &&  _texture)
noexcept
Move constructor.
[in]_textureHeightmapTexture to move.
◆ ~HeightmapTexture()
virtual ~HeightmapTexture ( )
◆ Diffuse()
std::string Diffuse ( ) const
The diffuse map of the heightmap texture.
◆ Normal()
std::string Normal ( ) const
The normal map of the heightmap texture.
◆ operator=() [1/2]
HeightmapTexture& operator= ( const HeightmapTexture &  _texture)
[in]_textureThe heightmap texture to set values from.
*this
◆ operator=() [2/2]
HeightmapTexture& operator= ( HeightmapTexture &&  _texture)
[in]_textureHeightmap texture to move.
Reference to this.
◆ SetDiffuse()
void SetDiffuse ( const std::string &  _diffuse)
[in]_diffuseThe diffuse map of the heightmap texture.
◆ SetNormal()
void SetNormal ( const std::string &  _normal)
[in]_normalThe normal map of the heightmap texture.
References IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING, and IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING.
◆ SetSize()
void SetSize ( double  _size)
[in]_sizeThe size of the texture in meters.
◆ Size()
double Size ( ) const
The size of the heightmap texture in meters.
