gz/rendering/HeightmapDescriptor.hh
17 #ifndef IGNITION_RENDERING_HEIGHTMAPDESCRIPTOR_HH_
18 #define IGNITION_RENDERING_HEIGHTMAPDESCRIPTOR_HH_
20 #include <memory>
21 #include <string>
22 #include <ignition/common/HeightmapData.hh>
23 #include <ignition/common/SuppressWarning.hh>
24
27
28 namespace ignition
29 {
30 namespace rendering
31 {
32 inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
33  class HeightmapDescriptorPrivate;
34  class HeightmapTexturePrivate;
35  class HeightmapBlendPrivate;
36
38  class IGNITION_RENDERING_VISIBLE HeightmapTexture
39  {
41  public: HeightmapTexture();
42
45  public: HeightmapTexture(const HeightmapTexture &_texture);
46
49  public: HeightmapTexture(HeightmapTexture &&_texture) noexcept;
50
52  public: virtual ~HeightmapTexture();
53
58
62  public: HeightmapTexture &operator=(const HeightmapTexture &_texture);
63
66  public: double Size() const;
67
70  public: void SetSize(double _size);
71
74  public: std::string Diffuse() const;
75
78  public: void SetDiffuse(const std::string &_diffuse);
79
82  public: std::string Normal() const;
83
86  public: void SetNormal(const std::string &_normal);
87
92  };
93
95  class IGNITION_RENDERING_VISIBLE HeightmapBlend
96  {
98  public: HeightmapBlend();
99
102  public: HeightmapBlend(const HeightmapBlend &_blend);
103
106  public: HeightmapBlend(HeightmapBlend &&_blend) noexcept;
107
109  public: virtual ~HeightmapBlend();
110
115
119  public: HeightmapBlend &operator=(const HeightmapBlend &_blend);
120
123  public: double MinHeight() const;
124
127  public: void SetMinHeight(double _minHeight);
128
131  public: double FadeDistance() const;
132
135  public: void SetFadeDistance(double _fadeDistance);
136
141  };
142
146  class IGNITION_RENDERING_VISIBLE HeightmapDescriptor
147  {
150
154
157  public: HeightmapDescriptor(HeightmapDescriptor &&_desc) noexcept;
158
160  public: virtual ~HeightmapDescriptor();
161
166
171
175  public: const std::string &Name() const;
176
179  public: void SetName(const std::string &_name);
180
184
188
192
195  public: void SetSize(const ignition::math::Vector3d &_size);
196
200
203  public: void SetPosition(const ignition::math::Vector3d &_position);
204
207  public: bool UseTerrainPaging() const;
208
211  public: void SetUseTerrainPaging(bool _use);
212
215  public: unsigned int Sampling() const;
216
219  public: void SetSampling(unsigned int _sampling);
220
223  public: uint64_t TextureCount() const;
224
231  public: const HeightmapTexture *TextureByIndex(uint64_t _index) const;
232
235  public: void AddTexture(const HeightmapTexture &_texture);
236
239  public: uint64_t BlendCount() const;
240
247  public: const HeightmapBlend *BlendByIndex(uint64_t _index) const;
248
251  public: void AddBlend(const HeightmapBlend &_blend);
252
258  };
259 }
260 }
261 }
262 #endif
Blend information to be used between textures on heightmaps.
Definition: gz/rendering/HeightmapDescriptor.hh:96
Get the heightmap blend's minimum height.
Set the distance over which the blend occurs.
Move constructor.
Get the heightmap blend's fade distance.
HeightmapBlend & operator=(HeightmapBlend &&_blend)
Move assignment operator.
Set the minimum height of the blend in meters.
Copy constructor.
HeightmapBlend & operator=(const HeightmapBlend &_blend)
Copy Assignment operator.
Describes how a Heightmap should be loaded.
Definition: gz/rendering/HeightmapDescriptor.hh:147
Move constructor.
Set the heightmap's name.
HeightmapDescriptor(const HeightmapDescriptor &_desc)
Copy constructor.
const std::string & Name() const
Get the heightmap's name used for caching. This is different from its unique Heightmap::Name().
Set whether the heightmap uses terrain paging. Defaults to false.
Get the number of heightmap blends.
Add a heightmap blend.
Set the heightmap's sampling. Defaults to 1.
Set the heightmap's scaling factor. Defaults to 1x1x1.
ignition::math::Vector3d Position() const
Get the heightmap's position offset.
std::shared_ptr< common::HeightmapData > Data() const
Get the heightfield data.
Set the heightmap's position offset.
HeightmapDescriptor & operator=(HeightmapDescriptor &&_desc)
ignition::math::Vector3d Size() const
Get the heightmap's scaling factor.
Add a heightmap texture.
HeightmapDescriptor & operator=(const HeightmapDescriptor &_desc)
Get the number of heightmap textures.
Get the heightmap's sampling per datum.
Get whether the heightmap uses terrain paging.
const HeightmapTexture * TextureByIndex(uint64_t _index) const
Get a heightmap texture based on an index.
void SetData(const std::shared_ptr< common::HeightmapData > &_data)
Set the heightfield data.
const HeightmapBlend * BlendByIndex(uint64_t _index) const
Get a heightmap blend based on an index.
Texture to be used on heightmaps.
Definition: gz/rendering/HeightmapDescriptor.hh:39
Copy constructor.
Get the heightmap texture's diffuse map.
HeightmapTexture & operator=(HeightmapTexture &&_texture)
HeightmapTexture & operator=(const HeightmapTexture &_texture)
Get the heightmap texture's normal map.
Move constructor.
double Size() const
Get the heightmap texture's size.
Set the filename of the diffuse map.
Set the filename of the normal map.
Set the size of the texture in meters.
