Base implementation of a joint visual. More...
#include <BaseJointVisual.hh>
virtual ~BaseJointVisual ()
virtual ignition::math::Vector3d Axis () const override
 Get axis vector. More...
virtual ignition::math::Vector3d ParentAxis () const override
virtual void SetAxis (const ignition::math::Vector3d &_axis, bool _useParentFrame) override
virtual void SetParentAxis (const ignition::math::Vector3d &_axis, const std::string &_parentName, bool _useParentFrame) override
virtual bool UpdateAxis (const ignition::math::Vector3d &_axis, bool _useParentFrame) override
virtual bool UpdateParentAxis (const ignition::math::Vector3d &_axis, bool _useParentFrame) override
virtual ~JointVisual ()
 BaseJointVisual ()
void CreateAxis ()
void CreateParentAxis ()
void ScaleToChild ()
void UpdateAxisImpl (ArrowVisualPtr _arrowVisual, const ignition::math::Vector3d &_axis, bool _useParentFrame)
ArrowVisualPtr arrowVisual = nullptr
ignition::math::Vector3d axis
AxisVisualPtr axisVisual = nullptr
bool dirtyAxis = false
bool dirtyJointType = false
bool dirtyParentAxis = false
std::string jointParentName = ""
 Joint parent name. More...
ignition::math::Vector3d parentAxis
 Parent axis vector. More...
bool parentAxisUseParentFrame = false
JointVisualPtr parentAxisVis = nullptr
ignition::math::Vector3d scaleToChild
bool updateAxis = false
bool updateParentAxis = false
bool useParentFrame = false
template<class T>
class ignition::rendering::BaseJointVisual< T >
◆ BaseJointVisual()
BaseJointVisual
◆ ~BaseJointVisual()
~BaseJointVisual
◆ ArrowVisual()
ArrowVisualPtr ArrowVisual ( ) const
Arrow visual.
Implements JointVisual.
◆ Axis()
ignition::math::Vector3d Axis ( ) const
Get axis vector.
The axis vector.
◆ CreateAxis()
void CreateAxis
References Scene::CreateArrowVisual().
◆ CreateParentAxis()
References Scene::CreateJointVisual(), ignlog, and Scene::NodeByName().
void Destroy ( )
void Init
◆ ParentAxis()
ignition::math::Vector3d ParentAxis ( ) const
The parent axis vector.
◆ ParentAxisVisual()
JointVisualPtr ParentAxisVisual ( ) const
Parent axis visual.
void PreRender ( )
◆ ScaleToChild()
void ScaleToChild
References std::max().
◆ SetAxis()
void SetAxis ( const ignition::math::Vector3d &  _axis,
[in]_axisAxis vector.
[in]_useParentFrameTrue if axis vector is expressed in parent frame.
◆ SetParentAxis()
void SetParentAxis ( const ignition::math::Vector3d &  _axis,
const std::string &  _parentName,
[in]_parentNameJoint parent name.
References ignlog, ignition::rendering::JVT_REVOLUTE2, and ignition::rendering::JVT_UNIVERSAL.
◆ SetType()
void SetType ( const JointVisualType  _type)
[in]_typeThe type of visualisation for joint.
◆ SetVisible()
Implements Visual.
References ignition::rendering::JVT_REVOLUTE2, ignition::rendering::JVT_UNIVERSAL, and Visual::SetVisible().
◆ Type()
JointVisualType Type ( ) const
The joint visual type.
◆ UpdateAxis()
bool UpdateAxis ( const ignition::math::Vector3d &  _axis,
True if axis was updated else false.
◆ UpdateAxisImpl()
void UpdateAxisImpl ( ArrowVisualPtr  _arrowVisual,
◆ UpdateParentAxis()
bool UpdateParentAxis ( const ignition::math::Vector3d &  _axis,
True if parent axis was updated else false.
◆ arrowVisual
◆ axis
Initial value:
◆ axisVisual
◆ dirtyAxis
◆ dirtyJointType
◆ dirtyParentAxis
◆ jointParentName
Joint parent name.
◆ jointVisualType
Initial value:
@ JVT_NONE
No type.
Definition: gz/rendering/JointVisual.hh:39
◆ parentAxis
Initial value:
Parent axis vector.
◆ parentAxisUseParentFrame
◆ parentAxisVis
◆ scaleToChild
Initial value:
◆ updateAxis
◆ updateParentAxis
◆ useParentFrame
