ArrowVisual Class Referenceabstract
Represents a arrow composite visual. More...
#include <ignition/rendering/ArrowVisual.hh>
virtual ~ArrowVisual ()
virtual VisualPtr Head () const =0
virtual VisualPtr Rotation () const =0
virtual VisualPtr Shaft () const =0
virtual void ShowArrowHead (bool _b)=0
virtual void ShowArrowRotation (bool _b)=0
virtual void ShowArrowShaft (bool _b)=0
virtual ~CompositeVisual ()
◆ ~ArrowVisual()
virtual ~ArrowVisual ( )
inlinevirtual
Deconstructor.
◆ Head()
virtual VisualPtr Head ( ) const
The arrow-head visual
Implemented in BaseArrowVisual< T >, BaseArrowVisual< OgreVisual >, and BaseArrowVisual< Ogre2Visual >.
◆ Rotation()
virtual VisualPtr Rotation ( ) const
The arrow-rotation visual
◆ Shaft()
virtual VisualPtr Shaft ( ) const
The arrow-shaft visual
◆ ShowArrowHead()
virtual void ShowArrowHead ( bool  _b)
[in]_btrue to show the arrow head, false otherwise
◆ ShowArrowRotation()
virtual void ShowArrowRotation ( bool  _b)
[in]_bTrue to show the arrow rotation.
◆ ShowArrowShaft()
virtual void ShowArrowShaft ( bool  _b)
[in]_btrue to show the arrow shaft, false otherwise
