A LidarVisual geometry class. The visual appearance is based on the type specified. More...
#include <ignition/rendering/LidarVisual>
virtual ~LidarVisual ()
virtual void ClearPoints ()=0
virtual bool DisplayNonHitting () const =0
virtual unsigned int HorizontalRayCount () const =0
virtual double MaxHorizontalAngle () const =0
virtual double MaxRange () const =0
virtual double MaxVerticalAngle () const =0
virtual double MinHorizontalAngle () const =0
virtual double MinRange () const =0
virtual double MinVerticalAngle () const =0
virtual ignition::math::Pose3d Offset () const =0
 Get offset of visual. More...
virtual unsigned int PointCount () const =0
virtual std::vector< double > Points () const =0
virtual void SetDisplayNonHitting (bool _display)=0
virtual void SetHorizontalRayCount (unsigned int _horizontalRayCount)=0
virtual void SetMaxHorizontalAngle (double _maxHorizontalAngle)=0
virtual void SetMaxRange (double _maxRange)=0
virtual void SetMaxVerticalAngle (double _maxVerticalAngle)=0
virtual void SetMinHorizontalAngle (double _minHorizontalAngle)=0
virtual void SetMinRange (double _minRange)=0
virtual void SetMinVerticalAngle (double _minVerticalAngle)=0
virtual void SetOffset (const ignition::math::Pose3d _offset)=0
 Set offset of visual. More...
virtual void SetPoints (const std::vector< double > &_points)=0
virtual void SetPoints (const std::vector< double > &_points, const std::vector< ignition::math::Color > &_colors)=0
virtual void SetSize (double _size)=0
virtual void SetType (const LidarVisualType _type)=0
virtual void SetVerticalRayCount (unsigned int _verticalRayCount)=0
virtual LidarVisualType Type () const =0
virtual void Update ()=0
 Update the Visual. More...
virtual unsigned int VerticalRayCount () const =0
 LidarVisual ()
◆ LidarVisual()
LidarVisual ( )
◆ ~LidarVisual()
virtual ~LidarVisual ( )
◆ ClearPoints()
virtual void ClearPoints ( )
◆ DisplayNonHitting()
virtual bool DisplayNonHitting ( ) const
Boolean value if non-hitting rays will be displayed
Implemented in BaseLidarVisual< T >, BaseLidarVisual< OgreVisual >, and BaseLidarVisual< Ogre2Visual >.
◆ HorizontalRayCount()
virtual unsigned int HorizontalRayCount ( ) const
The number of horizontal rays
◆ MaxHorizontalAngle()
virtual double MaxHorizontalAngle ( ) const
The maximum horizontal angle value of the lidar visual
◆ MaxRange()
virtual double MaxRange ( ) const
The maximum range for lidar rays
◆ MaxVerticalAngle()
virtual double MaxVerticalAngle ( ) const
The maximum vertical angle value of the lidar visual
◆ MinHorizontalAngle()
virtual double MinHorizontalAngle ( ) const
The minimum horizontal angle value of the lidar visual
◆ MinRange()
virtual double MinRange ( ) const
The minimum range for lidar rays
◆ MinVerticalAngle()
virtual double MinVerticalAngle ( ) const
The minimum vertical angle value of the lidar visual
◆ Offset()
virtual ignition::math::Pose3d Offset ( ) const
The offset of the lidar rays from visual origin
◆ PointCount()
Implemented in Ogre2LidarVisual, OgreLidarVisual, BaseLidarVisual< T >, BaseLidarVisual< OgreVisual >, and BaseLidarVisual< Ogre2Visual >.
◆ Points()
The points in the laser data
◆ SetDisplayNonHitting()
virtual void SetDisplayNonHitting ( bool  _display)
[in]_displayBoolean value to display non hitting visuals
◆ SetHorizontalRayCount()
virtual void SetHorizontalRayCount ( unsigned int  _horizontalRayCount)
_horizontalRayCount Number of vertical rays
◆ SetMaxHorizontalAngle()
virtual void SetMaxHorizontalAngle ( double  _maxHorizontalAngle)
[in]_maxHorizontalAngleMaximum horizontal angle value
◆ SetMaxRange()
virtual void SetMaxRange ( double  _maxRange)
[in]_maxRangeThe maximum range for lidar rays
◆ SetMaxVerticalAngle()
virtual void SetMaxVerticalAngle ( double  _maxVerticalAngle)
[in]_maxVerticalAngleMaximum vertical angle value
◆ SetMinHorizontalAngle()
virtual void SetMinHorizontalAngle ( double  _minHorizontalAngle)
[in]_minHorizontalAngleMinimum horizontal angle value
◆ SetMinRange()
virtual void SetMinRange ( double  _minRange)
[in]_minRangeThe minimum range for lidar rays
◆ SetMinVerticalAngle()
virtual void SetMinVerticalAngle ( double  _minVerticalAngle)
[in]_minVerticalAngleMinimum vertical angle
◆ SetOffset()
virtual void SetOffset ( const ignition::math::Pose3d  _offset)
[in]_offsetThe offset of the lidar rays from visual origin
◆ SetPoints() [1/2]
◆ SetPoints() [2/2]
virtual void SetPoints ( const std::vector< double > &  _points,
const std::vector< ignition::math::Color > &  _colors
Implemented in OgreLidarVisual, BaseLidarVisual< T >, BaseLidarVisual< OgreVisual >, and BaseLidarVisual< Ogre2Visual >.
◆ SetSize()
virtual void SetSize ( double  _size)
[in]_sizeSize of the lidar visualization.
◆ SetType()
virtual void SetType ( const LidarVisualType  _type)
[in]_typeThe type of visualisation for lidar data
◆ SetVerticalRayCount()
virtual void SetVerticalRayCount ( unsigned int  _verticalRayCount)
[in]_verticalRayCountNumber of vertical rays
◆ Size()
virtual double Size ( ) const
SetSize
◆ Type()
virtual LidarVisualType Type ( ) const
The type for lidar visual
virtual void Update ( )
◆ VerticalRayCount()
virtual unsigned int VerticalRayCount ( ) const
The number of vertical rays
