gz/rendering/LidarVisual.hh
17 #ifndef IGNITION_RENDERING_LIDARVISUAL_HH_
18 #define IGNITION_RENDERING_LIDARVISUAL_HH_
20 #include <vector>
21 #include <ignition/common/Time.hh>
22 #include <ignition/math/Color.hh>
23 #include <ignition/math/Vector3.hh>
29
30 namespace ignition
31 {
32  namespace rendering
33  {
34  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
35  //
37  enum IGNITION_RENDERING_VISIBLE LidarVisualType
38  {
40  LVT_NONE = 0,
41
44
47
50  };
51
55  class IGNITION_RENDERING_VISIBLE LidarVisual :
56  public virtual Visual
57  {
58  protected: LidarVisual();
59
61  public: virtual ~LidarVisual();
62
64  public: virtual void ClearPoints() = 0;
65
67  public: virtual void Update() = 0;
68
71  public: virtual void SetPoints(const std::vector<double> &_points) = 0;
72
76  public: virtual void SetPoints(const std::vector<double> &_points,
77  const std::vector<ignition::math::Color> &_colors) = 0;
78
81  public: virtual void SetMinVerticalAngle(
82  double _minVerticalAngle) = 0;
83
86  public: virtual double MinVerticalAngle() const = 0;
87
90  public: virtual void SetMaxVerticalAngle(
91  double _maxVerticalAngle) = 0;
92
95  public: virtual double MaxVerticalAngle() const = 0;
96
99  public: virtual void SetMinHorizontalAngle(
100  double _minHorizontalAngle) = 0;
101
104  public: virtual double MinHorizontalAngle() const = 0;
105
108  public: virtual void SetMaxHorizontalAngle(
109  double _maxHorizontalAngle) = 0;
110
113  public: virtual double MaxHorizontalAngle() const = 0;
114
117  public: virtual void SetVerticalRayCount(
118  unsigned int _verticalRayCount) = 0;
119
122  public: virtual unsigned int VerticalRayCount() const = 0;
123
126  public: virtual void SetHorizontalRayCount(
127  unsigned int _horizontalRayCount) = 0;
128
131  public: virtual unsigned int HorizontalRayCount() const = 0;
132
135  public: virtual void SetMinRange(double _minRange) = 0;
136
139  public: virtual double MinRange() const = 0;
140
143  public: virtual void SetMaxRange(double _maxRange) = 0;
144
147  public: virtual double MaxRange() const = 0;
148
151  public: virtual void SetOffset(
152  const ignition::math::Pose3d _offset) = 0;
153
156  public: virtual ignition::math::Pose3d Offset() const = 0;
157
160  public: virtual unsigned int PointCount() const = 0;
161
164  public: virtual std::vector<double> Points() const = 0;
165
168  public: virtual void SetType(const LidarVisualType _type) = 0;
169
172  public: virtual LidarVisualType Type() const = 0;
173
177  public: virtual void SetSize(double _size) = 0;
178
182  public: virtual double Size() const = 0;
183
187  public: virtual void SetDisplayNonHitting(bool _display) = 0;
188
191  public: virtual bool DisplayNonHitting() const = 0;
192  };
193  }
194  }
195 }
196 #endif
A LidarVisual geometry class. The visual appearance is based on the type specified.
Definition: gz/rendering/LidarVisual.hh:57
virtual double MinHorizontalAngle() const =0
Get minimum horizontal angle.
virtual void SetMaxVerticalAngle(double _maxVerticalAngle)=0
Set maximum vertical angle.
virtual void SetPoints(const std::vector< double > &_points)=0
Set lidar points to be visualised.
virtual void Update()=0
Update the Visual.
virtual void SetType(const LidarVisualType _type)=0
Set type for lidar visual.
virtual unsigned int PointCount() const =0
Get number of points in laser data.
virtual void SetSize(double _size)=0
Set size of the lidar visualization, e.g. size of rasterized lidar points in pixels.
virtual void ClearPoints()=0
Clear the points of the lidar visual.
virtual void SetMinVerticalAngle(double _minVerticalAngle)=0
Set minimum vertical angle.
virtual void SetMaxRange(double _maxRange)=0
Set maximum range of lidar rays.
virtual double Size() const =0
Get size of the lidar visualization.
virtual double MinRange() const =0
Get minimum range of lidar rays.
virtual unsigned int VerticalRayCount() const =0
Get number of vertical rays.
virtual void SetMinHorizontalAngle(double _minHorizontalAngle)=0
Set minimum horizontal angle.
virtual void SetVerticalRayCount(unsigned int _verticalRayCount)=0
Set number of vertical rays.
virtual double MinVerticalAngle() const =0
Get minimum vertical angle.
virtual void SetOffset(const ignition::math::Pose3d _offset)=0
Set offset of visual.
virtual std::vector< double > Points() const =0
Get the points in laser data.
virtual void SetHorizontalRayCount(unsigned int _horizontalRayCount)=0
Set number of horizontal rays.
virtual ignition::math::Pose3d Offset() const =0
Get offset of visual.
virtual unsigned int HorizontalRayCount() const =0
Get number of horizontal rays.
virtual void SetPoints(const std::vector< double > &_points, const std::vector< ignition::math::Color > &_colors)=0
virtual bool DisplayNonHitting() const =0
Get if non-hitting rays will be displayed.
virtual double MaxRange() const =0
Get maximum range of lidar rays.
virtual void SetMinRange(double _minRange)=0
Set minimum range of lidar rays.
virtual double MaxHorizontalAngle() const =0
Get maximum horizontal angle.
virtual void SetDisplayNonHitting(bool _display)=0
Set if non-hitting rays will be displayed (this does not work for TRIANGLE_STRIPS visual)
virtual LidarVisualType Type() const =0
Get the type for lidar visual.
virtual double MaxVerticalAngle() const =0
virtual void SetMaxHorizontalAngle(double _maxHorizontalAngle)=0
Set maximum horizontal angle.
Definition: gz/rendering/Visual.hh:35
LidarVisualType
Enum for LidarVisual types.
Definition: gz/rendering/LidarVisual.hh:38
@ LVT_TRIANGLE_STRIPS
Triangle strips visual.
Definition: gz/rendering/LidarVisual.hh:49
@ LVT_NONE
No type.
Definition: gz/rendering/LidarVisual.hh:40
@ LVT_POINTS
Points visual.
Definition: gz/rendering/LidarVisual.hh:46
@ LVT_RAY_LINES
Ray line visual.
Definition: gz/rendering/LidarVisual.hh:43
