Base implementation of a Lidar Visual. More...
#include <BaseLidarVisual.hh>
virtual ~BaseLidarVisual ()
virtual ignition::math::Pose3d Offset () const override
 Get offset of visual. More...
virtual void SetOffset (const ignition::math::Pose3d _offset) override
 Set offset of visual. More...
virtual void SetPoints (const std::vector< double > &_points, const std::vector< ignition::math::Color > &_colors) override
 Update the Visual. More...
virtual ~LidarVisual ()
 BaseLidarVisual ()
 LidarVisual ()
bool displayNonHitting = true
double horizontalAngleStep = 0
unsigned int horizontalCount = 1u
double maxHorizontalAngle = 0
double maxRange = 0
 Maximum Range. More...
double maxVerticalAngle = 0
double minHorizontalAngle = 0
double minRange = 0
 Minimum Range. More...
double minVerticalAngle = 0
ignition::math::Pose3d offset = ignition::math::Pose3d::Zero
 Offset of visual. More...
double size = 1.0
double verticalAngleStep = 0
unsigned int verticalCount = 1u
 Vertical laser count. More...
template<class T>
class ignition::rendering::BaseLidarVisual< T >
◆ BaseLidarVisual()
BaseLidarVisual
◆ ~BaseLidarVisual()
~BaseLidarVisual
◆ ClearPoints()
void ClearPoints ( )
Implements LidarVisual.
Reimplemented in Ogre2LidarVisual, and OgreLidarVisual.
◆ CreateMaterials()
References Scene::CreateMaterial().
void Destroy ( )
◆ DisplayNonHitting()
bool DisplayNonHitting ( ) const
Boolean value if non-hitting rays will be displayed
◆ HorizontalRayCount()
unsigned int HorizontalRayCount ( ) const
The number of horizontal rays
void Init
◆ MaxHorizontalAngle()
double MaxHorizontalAngle ( ) const
The maximum horizontal angle value of the lidar visual
◆ MaxRange()
double MaxRange ( ) const
The maximum range for lidar rays
◆ MaxVerticalAngle()
double MaxVerticalAngle ( ) const
The maximum vertical angle value of the lidar visual
◆ MinHorizontalAngle()
double MinHorizontalAngle ( ) const
The minimum horizontal angle value of the lidar visual
◆ MinRange()
double MinRange ( ) const
The minimum range for lidar rays
◆ MinVerticalAngle()
double MinVerticalAngle ( ) const
The minimum vertical angle value of the lidar visual
◆ Offset()
ignition::math::Pose3d Offset ( ) const
The offset of the lidar rays from visual origin
◆ PointCount()
◆ Points()
std::vector< double > Points ( ) const
The points in the laser data
void PreRender ( )
◆ SetDisplayNonHitting()
void SetDisplayNonHitting ( bool  _display)
[in]_displayBoolean value to display non hitting visuals
◆ SetHorizontalRayCount()
void SetHorizontalRayCount ( unsigned int  _horizontalRayCount)
_horizontalRayCount Number of vertical rays
References std::endl(), and ignwarn.
◆ SetMaxHorizontalAngle()
void SetMaxHorizontalAngle ( double  _maxHorizontalAngle)
[in]_maxHorizontalAngleMaximum horizontal angle value
◆ SetMaxRange()
void SetMaxRange ( double  _maxRange)
[in]_maxRangeThe maximum range for lidar rays
◆ SetMaxVerticalAngle()
void SetMaxVerticalAngle ( double  _maxVerticalAngle)
[in]_maxVerticalAngleMaximum vertical angle value
◆ SetMinHorizontalAngle()
void SetMinHorizontalAngle ( double  _minHorizontalAngle)
[in]_minHorizontalAngleMinimum horizontal angle value
◆ SetMinRange()
void SetMinRange ( double  _minRange)
[in]_minRangeThe minimum range for lidar rays
◆ SetMinVerticalAngle()
void SetMinVerticalAngle ( double  _minVerticalAngle)
[in]_minVerticalAngleMinimum vertical angle
◆ SetOffset()
void SetOffset ( const ignition::math::Pose3d  _offset)
[in]_offsetThe offset of the lidar rays from visual origin
◆ SetPoints() [1/2]
void SetPoints ( const std::vector< double > &  _points)
◆ SetPoints() [2/2]
void SetPoints ( const std::vector< double > &  _points,
const std::vector< ignition::math::Color > &  _colors
Reimplemented in OgreLidarVisual.
◆ SetSize()
void SetSize ( double  _size)
[in]_sizeSize of the lidar visualization.
◆ SetType()
void SetType ( const LidarVisualType  _type)
[in]_typeThe type of visualisation for lidar data
◆ SetVerticalRayCount()
void SetVerticalRayCount ( unsigned int  _verticalRayCount)
[in]_verticalRayCountNumber of vertical rays
◆ Size()
double Size ( ) const
SetSize
◆ Type()
LidarVisualType Type ( ) const
The type for lidar visual
void Update ( )
Update the Visual.
◆ VerticalRayCount()
unsigned int VerticalRayCount ( ) const
The number of vertical rays
◆ displayNonHitting
◆ horizontalAngleStep
◆ horizontalCount
◆ lidarVisualType
Initial value:
@ LVT_TRIANGLE_STRIPS
Triangle strips visual.
Definition: gz/rendering/LidarVisual.hh:49
◆ maxHorizontalAngle
◆ maxRange
double maxRange = 0
Maximum Range.
◆ maxVerticalAngle
◆ minHorizontalAngle
◆ minRange
double minRange = 0
Minimum Range.
◆ minVerticalAngle
◆ offset
Offset of visual.
◆ size
double size = 1.0
◆ verticalAngleStep
◆ verticalCount
