LightVisual Class Referenceabstract
Represents a light visual. More...
#include <ignition/rendering/LightVisual.hh>
virtual ~LightVisual ()
 Descructor. More...
virtual double InnerAngle ()=0
 Get inner angle. More...
virtual double OuterAngle ()=0
 Get outer angle. More...
virtual void SetInnerAngle (double _innerAngle)=0
virtual void SetOuterAngle (double _outerAngle)=0
virtual void SetType (LightVisualType _type)=0
 set type of the light More...
virtual LightVisualType Type ()=0
◆ ~LightVisual()
virtual ~LightVisual ( )
inlinevirtual
Descructor.
◆ InnerAngle()
virtual double InnerAngle ( )
Get inner angle.
The light inner angle
Implemented in BaseLightVisual< T >, BaseLightVisual< OgreVisual >, and BaseLightVisual< Ogre2Visual >.
◆ OuterAngle()
virtual double OuterAngle ( )
Get outer angle.
The light outer angle
◆ SetInnerAngle()
virtual void SetInnerAngle ( double  _innerAngle)
[in]_innerAngleInner angle
◆ SetOuterAngle()
virtual void SetOuterAngle ( double  _outerAngle)
[in]_outerAngleOuter angle
◆ SetType()
virtual void SetType ( LightVisualType  _type)
[in]_typetype of the light
◆ Type()
virtual LightVisualType Type ( )
The light visual type
