SubMesh Class Referenceabstract
Represents a single mesh geometry. More...
#include <ignition/rendering/Mesh.hh>
virtual ~SubMesh ()
 Get the currently assigned material. More...
 Set the materials of this SubMesh. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More...
 Set the materials of this SubMesh. More...
◆ ~SubMesh()
virtual ~SubMesh ( )
inlinevirtual
Deconstructor.
The currently assigned material
Implemented in BaseSubMesh< T >, BaseSubMesh< Ogre2Object >, and BaseSubMesh< OgreObject >.
◆ SetMaterial() [1/2]
bool  _unique = true
◆ SetMaterial() [2/2]
bool  _unique = true
