#include <Ogre2RayQuery.hh>
virtual ~Ogre2RayQuery ()
virtual RayQueryResult ClosestPoint ()
virtual void SetFromCamera (const CameraPtr &_camera, const math::Vector2d &_coord)
- Public Member Functions inherited from BaseRayQuery< Ogre2Object >
 Get ray direction. More...
 Get ray origin. More...
 Set ray direction. More...
 Set ray origin. More...
virtual ~RayQuery ()
 Ogre2RayQuery ()
- Protected Member Functions inherited from BaseRayQuery< Ogre2Object >
 BaseRayQuery ()
virtual void Init ()
- Protected Attributes inherited from BaseRayQuery< Ogre2Object >
math::Vector3d direction
 Ray direction. More...
 Ray origin. More...
ignition/rendering/ogre2/Ogre2RayQuery.hh
◆ Ogre2RayQuery()
Ogre2RayQuery ( )
◆ ~Ogre2RayQuery()
virtual ~Ogre2RayQuery ( )
◆ ClosestPoint()
virtual RayQueryResult ClosestPoint ( )
Reimplemented from BaseRayQuery< Ogre2Object >.
◆ SetFromCamera()
