virtual ~OgreRenderTexture ()
virtual void Buffer (float *buffer)
virtual unsigned int GLId ()
virtual Ogre::RenderTarget * RenderTarget () const override
- Public Member Functions inherited from BaseRenderTexture< OgreRenderTarget >
 BaseRenderTexture ()
virtual ~BaseRenderTexture ()
virtual unsigned int GLId () const override
virtual ~RenderTexture ()
virtual ~RenderTarget ()
- Public Member Functions inherited from OgreRenderTarget
virtual ~OgreRenderTarget ()
virtual void Render ()
 Set visibility mask for the viewport associated with this render target. More...
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
virtual void BuildTarget ()
virtual void DestroyTarget ()
- Protected Member Functions inherited from OgreRenderTarget
 OgreRenderTarget ()
void RebuildMaterial ()
virtual void Rebuild ()
virtual void Init ()
Ogre::Texture * ogreTexture = nullptr
- Protected Attributes inherited from OgreRenderTarget
unsigned int antiAliasing = 4
bool colorDirty = true
uint32_t visibilityMask = IGN_VISIBILITY_ALL
 visibility mask associated with this render target More...
PixelFormat format
unsigned int height
bool renderPassDirty
bool targetDirty
unsigned int width
◆ OgreRenderTexture()
OgreRenderTexture ( )
◆ ~OgreRenderTexture()
virtual ~OgreRenderTexture ( )
◆ Buffer()
virtual void Buffer ( float *  buffer)
◆ BuildTarget()
virtual void BuildTarget ( )
Implements OgreRenderTarget.
◆ DestroyTarget()
virtual void DestroyTarget ( )
◆ GLId()
virtual unsigned int GLId ( )
◆ PostRender()
virtual void PostRender ( )
Reimplemented from OgreRenderTarget.
◆ RebuildTarget()
◆ RenderTarget()
◆ ogreTexture
Ogre::Texture* ogreTexture = nullptr
