gz/rendering/ogre/OgreRenderTarget.hh
Definition: gz/rendering/base/BaseRenderTarget.hh:38
Definition: gz/rendering/base/BaseRenderTarget.hh:101
Definition: gz/rendering/base/BaseRenderTarget.hh:114
Definition: gz/rendering/Image.hh:40
Definition: gz/rendering/ogre/OgreRenderTarget.hh:45
Ogre::Viewport * AddViewport(Ogre::Camera *_viewport)
virtual void SetVisibilityMask(uint32_t _mask)
Set visibility mask for the viewport associated with this render target.
virtual void Render()
virtual void RebuildViewport()
virtual unsigned int AntiAliasing() const
void SetAutoUpdated(const bool _value)
virtual void Copy(Image &_image) const override
Write rendered image to given Image. The RenderTarget will convert the underlying image to the specif...
virtual void SetCamera(Ogre::Camera *_camera)
void RebuildMaterial()
Re-initializes render target material to apply a material to everything in the scene....
Ogre::Viewport * Viewport(const int _viewportId) const
virtual Ogre::RenderTarget * RenderTarget() const =0
virtual void UpdateRenderPassChain()
Update render pass chain if changes were made.
virtual void SetBackgroundColor(math::Color _color)
Ogre::ColourValue ogreBackgroundColor
Definition: gz/rendering/ogre/OgreRenderTarget.hh:124
virtual ~OgreRenderTarget()
OgreRenderTarget()
virtual void PostRender() override
void SetMaterial(MaterialPtr _material)
Set a material to render on every object. This method is used for special cases like the render targe...
virtual void RebuildTarget()=0
void SetUpdate(const bool _value)
virtual void SetAntiAliasing(unsigned int _aa)
OgreRenderTargetMaterialPtr materialApplicator
Helper class that applies the material to the render target.
Definition: gz/rendering/ogre/OgreRenderTarget.hh:130
virtual void Destroy() override=0
virtual void UpdateBackgroundColor()
virtual math::Color BackgroundColor() const override
virtual void RebuildImpl() override
virtual Ogre::Camera * Camera() const
a material used by for the render target
Definition: gz/rendering/ogre/OgreRenderTarget.hh:127
Definition: gz/rendering/ogre/OgreRenderTarget.hh:142
virtual void BuildTarget()
virtual Ogre::RenderTarget * RenderTarget() const override
virtual void RebuildTarget() override
virtual void DestroyTarget()
virtual void Buffer(float *buffer)
OgreRenderTexture()
virtual unsigned int GLId()
virtual ~OgreRenderTexture()
Definition: gz/rendering/ogre/OgreRenderTarget.hh:175
OgreRenderWindow()
virtual ~OgreRenderWindow()
Definition: gz/rendering/ogre/OgreScene.hh:41
Non owning, writable view of a caller owned pixel buffer.
Definition: gz/rendering/PixelBuffer.hh:49
#define IGN_VISIBILITY_ALL
Render everything visibility mask.
Definition: gz/rendering/RenderTypes.hh:26
