DepthCamera Class Referenceabstract
#include <DepthCamera.hh>
Public Types
virtual ~DepthCamera ()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0
 Connect to the new depth image signal. More...
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal. More...
virtual void CreateDepthTexture ()=0
 Create a texture which will hold the depth data. More...
virtual const float * DepthData () const =0
 All things needed to get back z buffer for depth data. More...
virtual ~Camera ()
virtual void Render ()=0
virtual void SetImageFormat (PixelFormat _format)=0
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
Member Typedef Documentation
◆ NewFrameListener
typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener
◆ ~DepthCamera()
virtual ~DepthCamera ( )
inlinevirtual
◆ ConnectNewDepthFrame()
virtual gz::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Implemented in Ogre2DepthCamera, OgreDepthCamera, BaseDepthCamera< T >, BaseDepthCamera< Ogre2Sensor >, and BaseDepthCamera< OgreSensor >.
◆ ConnectNewRgbPointCloud()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud ( std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)>  _subscriber)
[in]_subscriberSubscriber callback function The arguments of the callback function are: _pointCloud Point cloud data. Each point is represented by four 32 bit floating point values [X, Y, Z, RGBA]. The last field can be decoded into 4 unsigned 8 bit color values: uint32_t *rgba = reinterpret_cast<uint32_t *>(&_rgba) r = static_cast<uint8_t>(*rgba >> 24 & 0xFF); g = static_cast<uint8_t>(*rgba >> 16 & 0xFF); b = static_cast<uint8_t>(*rgba >> 8 & 0xFF); a = static_cast<uint8_t>(*rgba >> 0 & 0xFF); _width Point cloud image width _height Point cloud image height _depth Point cloud image depth _format Point cloud image format
◆ CreateDepthTexture()
virtual void CreateDepthTexture ( )
◆ DepthData()
virtual const float* DepthData ( ) const
The z-buffer as a float array
