ShaderParam Class Reference
a variant type that holds params that can be passed to a shader More...
#include <ShaderParam.hh>
Public Types
enum  ParamType : uint16_t {
  PARAM_NONE = 0 , PARAM_FLOAT = 1 , PARAM_INT = 2 , PARAM_FLOAT_BUFFER = 3 ,
  PARAM_INT_BUFFER = 4 , PARAM_TEXTURE = 5 , PARAM_TEXTURE_CUBE = 6
 ShaderParam ()
 constructor More...
 ShaderParam (const ShaderParam &_other)
 copy constructor More...
 ~ShaderParam ()
 destructor More...
bool Buffer (std::shared_ptr< void > &_buffer) const
 Get the value of this parameter if it is a buffer. More...
uint32_t Count () const
 Get the element count of this parameter's buffer. More...
void InitializeBuffer (uint32_t _count)
 Set this to be a buffer parameter. More...
void operator= (const float _value)
 Set this to be a float parameter. More...
void operator= (const int _value)
 Set this to be an integer parameter. More...
ShaderParam & operator= (const ShaderParam &_other)
 Set from another ShaderParam. More...
void SetTexture (const std::string &_value, ShaderParam::ParamType _type=ShaderParam::ParamType::PARAM_TEXTURE, uint32_t _uvSetIndex=0u)
 Set this to be a texture parameter. More...
ParamType Type () const
 Get the type of this parameter. More...
void UpdateBuffer (float *_floatBuffer)
 Copy a buffer to this parameter. More...
void UpdateBuffer (int *_intBuffer)
bool Value (float *_value) const
 Get the value of this parameter if it is a float. More...
bool Value (int *_value) const
 Get the value of this parameter if it is an int. More...
bool Value (std::string &_value, uint32_t &_uvSetIndex) const
 Get the value of this parameter if it is a texture. More...
◆ ParamType
Enumerator
PARAM_NONE
Type none.
PARAM_FLOAT
Float type parameter.
PARAM_INT
Integer type parameter.
PARAM_FLOAT_BUFFER
Float Buffer type parameter.
PARAM_INT_BUFFER
Int Buffer type parameter.
PARAM_TEXTURE
texture type parameter
PARAM_TEXTURE_CUBE
cube map type parameter
◆ ShaderParam() [1/2]
constructor
◆ ShaderParam() [2/2]
ShaderParam ( const ShaderParam &  _other)
copy constructor
[in]_otherAnother ShaderParam
◆ ~ShaderParam()
destructor
◆ Buffer()
bool Buffer ( std::shared_ptr< void > &  _buffer) const
[out]_buffervariable the value will be copied to
true if the parameter is the expected type
References IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING, and IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING.
◆ Count()
uint32_t Count ( ) const
Count of elements in this parameter's buffer
◆ InitializeBuffer()
void InitializeBuffer ( uint32_t  _count)
[in]_countNumber of 32-bit elements in the buffer
◆ operator=() [1/3]
void operator= ( const float  _value)
[in]_valueValue to set this parameter to
◆ operator=() [2/3]
void operator= ( const int  _value)
◆ operator=() [3/3]
ShaderParam& operator= ( const ShaderParam &  _other)
Reference to this ShaderParam
◆ SetTexture()
void SetTexture ( const std::string &  _value,
ShaderParam::ParamType  _type = ShaderParam::ParamType::PARAM_TEXTURE,
uint32_t  _uvSetIndex = 0u
[in]_typeType of texture
[in]_uvSetIndexTexture coordinate set index
◆ Type()
ParamType Type ( ) const
Type of this parameter
◆ UpdateBuffer() [1/2]
void UpdateBuffer ( float *  _floatBuffer)
[in]_floatBufferSource buffer to copy from
◆ UpdateBuffer() [2/2]
void UpdateBuffer ( int *  _intBuffer)
[in]_intBufferSource buffer to copy from
◆ Value() [1/3]
bool Value ( float *  _value) const
[out]_valuevariable the value will be copied to
◆ Value() [2/3]
bool Value ( int *  _value) const
◆ Value() [3/3]
bool Value ( std::string &  _value,
uint32_t &  _uvSetIndex
) const
[out]_uvSetIndexTexture coordinate set index
true if the parameter filled
