gz/rendering/ShaderParam.hh
2  * Copyright (C) 2017 Open Source Robotics Foundation
17
18 #ifndef GZ_RENDERING_SHADERPARAM_HH_
19 #define GZ_RENDERING_SHADERPARAM_HH_
20
21 #include <cstdint>
22 #include <cstring>
23 #include <memory>
24 #include <string>
25
26 #include <gz/common/SuppressWarning.hh>
27
28 #include "gz/rendering/config.hh"
29 #include "gz/rendering/Export.hh"
30
31 namespace ignition
32 {
33  namespace rendering
34  {
35  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
36  //
38  class ShaderParamPrivate;
39
41  class IGNITION_RENDERING_VISIBLE ShaderParam
42  {
43  public: enum ParamType : uint16_t
44  {
46  PARAM_NONE = 0,
47
49  PARAM_FLOAT = 1,
50
52  PARAM_INT = 2,
53
55  PARAM_FLOAT_BUFFER = 3,
56
58  PARAM_INT_BUFFER = 4,
59
61  PARAM_TEXTURE = 5,
62
64  PARAM_TEXTURE_CUBE = 6,
65  };
66
68  public: ShaderParam();
69
72  public: ShaderParam(const ShaderParam &_other);
73
75  public: ~ShaderParam();
76
79  public: ParamType Type() const;
80
83  public: uint32_t Count() const;
84
88  public: ShaderParam &operator=(const ShaderParam &_other);
89
92  public: void operator=(const float _value);
93
96  public: void operator=(const int _value);
97
102  public: void SetTexture(const std::string &_value,
103  ShaderParam::ParamType _type = ShaderParam::ParamType::PARAM_TEXTURE,
104  uint32_t _uvSetIndex = 0u);
105
108  public: void InitializeBuffer(uint32_t _count);
109
112  public: void UpdateBuffer(float *_floatBuffer);
113
116  public: void UpdateBuffer(int *_intBuffer);
117
121  public: bool Value(float *_value) const;
122
126  public: bool Value(int *_value) const;
127
132  public: bool Value(std::string &_value, uint32_t &_uvSetIndex) const;
133
137  public: bool Buffer(std::shared_ptr<void> &_buffer) const;
138
141  private: std::unique_ptr<ShaderParamPrivate> dataPtr;
143  };
144  }
145  }
146 }
147
148 #endif
a variant type that holds params that can be passed to a shader
Definition: gz/rendering/ShaderParam.hh:42
Get the element count of this parameter's buffer.
void SetTexture(const std::string &_value, ShaderParam::ParamType _type=ShaderParam::ParamType::PARAM_TEXTURE, uint32_t _uvSetIndex=0u)
Set this to be a texture parameter.
Get the type of this parameter.
Copy a buffer to this parameter.
copy constructor
Get the value of this parameter if it is an int.
Get the value of this parameter if it is a texture.
Set this to be a buffer parameter.
ParamType
Definition: gz/rendering/ShaderParam.hh:44
bool Buffer(std::shared_ptr< void > &_buffer) const
Get the value of this parameter if it is a buffer.
Set this to be a float parameter.
Set this to be an integer parameter.
Get the value of this parameter if it is a float.
ShaderParam & operator=(const ShaderParam &_other)
Set from another ShaderParam.
