gz/rendering/ogre2/Ogre2Heightmap.hh
16 */
17
18 #ifndef IGNITION_RENDERING_OGRE2_OGRE2HEIGHTMAP_HH_
19 #define IGNITION_RENDERING_OGRE2_OGRE2HEIGHTMAP_HH_
20
21 #include <memory>
22
25
26 // Ignoring warning: "non dll-interface class
27 // 'ignition::rendering::v5::Heightmap' used as base for dll-interface class"
28 // because `Heightmap` and `BaseHeightmap` are header-only
29 #ifdef _MSC_VER
30  #pragma warning(push)
31  #pragma warning(disable:4275)
32 #endif
33
34 namespace Ogre
35 {
36  class Camera;
37  class Terra;
38 }
39
40 namespace ignition
41 {
42  namespace rendering
43  {
44  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
45  //
46  // Forward declaration
47  class Ogre2HeightmapPrivate;
48
50  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2Heightmap
51  : public BaseHeightmap<Ogre2Geometry>
52  {
56  public: explicit Ogre2Heightmap(const HeightmapDescriptor &_desc);
57
59  public: virtual ~Ogre2Heightmap() override;
60
61  // Documentation inherited.
62  public: virtual void Init() override;
63
64  // Documentation inherited.
65  public: virtual void PreRender() override;
66
71  public: virtual Ogre::MovableObject *OgreObject() const override;
72
76  public: virtual MaterialPtr Material() const override;
77
82  public: virtual void SetMaterial(MaterialPtr _material, bool _unique)
83  override;
84
88  public: Ogre::Terra* Terra();
89
96  public: void UpdateForRender(Ogre::Camera *_activeCamera);
97
98  // Documentation inherited.
99  // \todo(iche033) rename this to Destroy and
100  // make this function public and virtual
101  private: void DestroyImpl();
102
104  private: friend class OgreScene;
105
108  };
109  }
110  }
111 }
112 #ifdef _MSC_VER
113  #pragma warning(pop)
114 #endif
115
116 #endif
Definition: gz/rendering/base/BaseHeightmap.hh:33
Describes how a Heightmap should be loaded.
Definition: gz/rendering/HeightmapDescriptor.hh:147
Ogre implementation of a heightmap geometry.
Definition: gz/rendering/ogre2/Ogre2Heightmap.hh:52
virtual Ogre::MovableObject * OgreObject() const override
Returns the Terra pointer as it is a movable object that must be attached to a regular SceneNode.
virtual void SetMaterial(MaterialPtr _material, bool _unique) override
Has no effect for heightmaps. The material is set through a HeightmapDescriptor.
Returns NULL, heightmap materials don't inherit from MaterialPtr.
Definition: gz/rendering/ogre/OgreScene.hh:41
