gz/rendering/ogre2/Ogre2MeshFactory.hh
17 #ifndef GZ_RENDERING_OGRE2_OGRE2MESHFACTORY_HH_
18 #define GZ_RENDERING_OGRE2_OGRE2MESHFACTORY_HH_
20 #include <memory>
21 #include <string>
22 #include <vector>
23
24 #include "gz/rendering/config.hh"
28 #include "gz/rendering/ogre2/Export.hh"
29
30 namespace Ogre
31 {
32  class Item;
33 }
34
35 namespace ignition
36 {
37  namespace rendering
38  {
39  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
40  //
41  // forward declaration
42  class Ogre2MeshFactoryPrivate;
43  class Ogre2SubMeshStoreFactoryPrivate;
44
46  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2MeshFactory
47  {
50  public: explicit Ogre2MeshFactory(Ogre2ScenePtr _scene);
51
53  public: virtual ~Ogre2MeshFactory();
54
58  public: virtual Ogre2MeshPtr Create(const MeshDescriptor &_desc);
59
62  public: virtual void Clear();
63
66  protected: virtual Ogre::Item *OgreItem(
67  const MeshDescriptor &_desc);
68
71  protected: virtual bool Load(const MeshDescriptor &_desc);
72
76  protected: virtual bool IsLoaded(const MeshDescriptor &_desc);
77
80  protected: virtual bool LoadImpl(const MeshDescriptor &_desc);
81
84  protected: virtual std::string MeshName(const MeshDescriptor &_desc);
85
89  protected: virtual bool Validate(const MeshDescriptor &_desc);
90
93
95  protected: Ogre2ScenePtr scene;
96
98  public: void ClearMaterialsCache(const std::string &_name);
99
102  };
103
105  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2SubMeshStoreFactory
106  {
111  Ogre::Item *_item);
112
114  public: virtual ~Ogre2SubMeshStoreFactory();
115
118  public: virtual Ogre2SubMeshStorePtr Create();
119
123  protected: virtual Ogre2SubMeshPtr CreateSubMesh(unsigned int _index);
124
126  protected: virtual void CreateNameList();
127
129  protected: virtual void PopulateDefaultNames();
130
133  protected: virtual void PopulateGivenNames();
134
136  protected: Ogre2ScenePtr scene;
137
139  protected: Ogre::Item *ogreItem = nullptr;
140
143
146  };
147  }
148  }
149 }
150 #endif
Ogre2.x implementation of the mesh factory class.
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:47
std::vector< std::string > ogreMeshes
A list of ogre meshes created by this factory.
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:92
Cleanup and clear all internal ogre v2 meshes created by this factory.
Validate the mesh descriptor to make sure it contains all the needed information to create a mesh.
Load a mesh using a mesh descriptor.
Get the mesh name from the mesh descriptor.
Remove internal material cache for a specific material.
Create a mesh from a descriptor.
Check if the mesh is loaded using a mesh descriptor.
Helper function to load the mesh from the input mesh descriptor.
virtual Ogre::Item * OgreItem(const MeshDescriptor &_desc)
Get the ogre item based on the mesh descriptor.
Ogre2ScenePtr scene
Pointer to the scene object.
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:95
Ogre2.x implementation of a submesh store factory class.
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:106
Populate the name list with names associated with each ogre subitem.
Create a list of names and the corresponding submesh object.
Ogre2SubMeshStoreFactory(Ogre2ScenePtr _scene, Ogre::Item *_item)
Populate the name list with default generated names.
std::vector< std::string > names
A list of names associated with each ogre subitem / submesh.
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:142
Create the submeshes.
Ogre2ScenePtr scene
Definition: gz/rendering/ogre2/Ogre2MeshFactory.hh:136
Helper function to create submesh at the given index.
Describes how a Mesh should be loaded.
Definition: gz/rendering/MeshDescriptor.hh:45
