gz/rendering/ogre2/Ogre2Node.hh
17 #ifndef GZ_RENDERING_OGRE2_OGRE2NODE_HH_
18 #define GZ_RENDERING_OGRE2_OGRE2NODE_HH_
23
24 namespace Ogre
25 {
26  class SceneNode;
27 }
28
29 namespace ignition
30 {
31  namespace rendering
32  {
33  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
34  //
36  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2Node :
37  public BaseNode<Ogre2Object>
38  {
40  protected: Ogre2Node();
41
43  public: virtual ~Ogre2Node();
44
45  // Documentation inherited.
46  public: virtual bool HasParent() const override;
47
48  // Documentation inherited.
49  public: virtual NodePtr Parent() const override;
50
53  public: virtual Ogre::SceneNode *Node() const;
54
55  // Documentation inherited.
56  public: virtual void Destroy() override;
57
58  // Documentation inherited.
59  public: virtual math::Vector3d LocalScale() const override;
60
61  // Documentation inherited.
62  public: virtual bool InheritScale() const override;
63
64  // Documentation inherited.
65  public: virtual void SetInheritScale(bool _inherit) override;
66
67  // Documentation inherited.
68  protected: virtual void SetLocalScaleImpl(
69  const math::Vector3d &_scale) override;
70
71  // Documentation inherited.
72  protected: virtual NodeStorePtr Children() const override;
73
74  // Documentation inherited.
75  protected: virtual bool AttachChild(NodePtr _child) override;
76
77  // Documentation inherited.
78  protected: virtual bool DetachChild(NodePtr _child) override;
79
80  // Documentation inherited.
81  protected: virtual math::Pose3d RawLocalPose() const override;
82
83  // Documentation inherited.
84  protected: virtual void SetRawLocalPose(const math::Pose3d &_Pose3d)
85  override;
86
89  protected: virtual math::Vector3d RawLocalPosition() const;
90
93  protected: virtual void SetRawLocalPosition(
94  const math::Vector3d &_position);
95
98  protected: virtual math::Quaterniond RawLocalRotation() const;
99
102  protected: virtual void SetRawLocalRotation(
103  const math::Quaterniond &_rotation);
104
107  protected: virtual void SetParent(Ogre2NodePtr _parent);
108
109  // Documentation inherited.
110  protected: virtual void Load() override;
111
112  // Documentation inherited.
113  protected: virtual void Init() override;
114
116  private: Ogre2NodePtr SharedThis();
117
119  protected: Ogre2NodePtr parent;
120
122  protected: Ogre::SceneNode *ogreNode = nullptr;
123
126
127  // TODO(anyone): remove the need for a visual friend class
128  private: friend class Ogre2Visual;
129  };
130  }
131  }
132 }
133 #endif
Definition: gz/rendering/base/BaseNode.hh:37
Ogre2.x implementation of the Node class.
Definition: gz/rendering/ogre2/Ogre2Node.hh:38
Determine if this visual inherits scale from this parent.
Ogre2NodePtr parent
Definition: gz/rendering/ogre2/Ogre2Node.hh:119
Specify if this visual inherits scale from its parent.
Set the parent node.
virtual Ogre::SceneNode * Node() const
Ogre2NodeStorePtr children
A list of child nodes.
Definition: gz/rendering/ogre2/Ogre2Node.hh:125
Get the local scale.
virtual void SetLocalScaleImpl(const math::Vector3d &_scale) override
virtual void SetRawLocalPosition(const math::Vector3d &_position)
virtual void SetRawLocalRotation(const math::Quaterniond &_rotation)
Get the parent Node.
virtual void SetRawLocalPose(const math::Pose3d &_Pose3d) override
Ogre2.x implementation of the visual class.
Definition: gz/rendering/ogre2/Ogre2Visual.hh:39
