gz/rendering/ogre/OgreGpuRays.hh
16 */
17
18 #ifndef GZ_RENDERING_OGRE_OGREGPURAYS_HH_
19 #define GZ_RENDERING_OGRE_OGREGPURAYS_HH_
20
21 #include <string>
22 #include <vector>
23 #include <memory>
24 #include <sstream>
25
26 #include <gz/common/SuppressWarning.hh>
27
37
38 #ifdef _WIN32
39  // Ensure that Winsock2.h is included before Windows.h, which can get
40  // pulled in by anybody (e.g., Boost).
41  #include <Winsock2.h>
42 #endif
43
44 namespace ignition
45 {
46  namespace rendering
47  {
48  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
49  //
50  // Forward declaration
51  class OgreGpuRaysPrivate;
52
57  class IGNITION_RENDERING_OGRE_VISIBLE OgreGpuRays :
58  public BaseGpuRays<OgreSensor>, public Ogre::RenderObjectListener
59  {
61  protected: OgreGpuRays();
62
64  public: virtual ~OgreGpuRays();
65
66  // Documentation inherited
67  public: virtual void Init() override;
68
69  // Documentation inherited
70  public: virtual void Destroy() override;
71
73  public: virtual void CreateRenderTexture();
74
75  // Documentation inherited
76  public: virtual void PreRender() override;
77
78  // Documentation inherited
79  public: virtual void PostRender() override;
80
81  // Documentation inherited
82  public: virtual const float *Data() const override;
83
84  // Documentation inherited.
85  public: virtual void Copy(float *_data) override;
86
87  // Documentation inherited.
89  std::function<void(const float *_frame, unsigned int _width,
90  unsigned int _height, unsigned int _channels,
91  const std::string &_format)> _subscriber) override;
92
93  // Documentation inherited.
94  public: virtual RenderTargetPtr RenderTarget() const override;
95
98  public: virtual void notifyRenderSingleObject(Ogre::Renderable *_rend,
99  const Ogre::Pass *_p, const Ogre::AutoParamDataSource *_s,
100  const Ogre::LightList *_ll, bool _supp) override;
101
106  private: virtual void Set1stTextureSize(const unsigned int _w,
107  const unsigned int _h = 1);
108
113  private: virtual void SetRangeCount(const unsigned int _w,
114  const unsigned int _h = 1);
115
116  // Documentation inherited.
117  private: virtual void Render() override;
118
120  private: void ConfigureCameras();
121
123  private: void CreateMesh();
124
126  private: void CreateCanvas();
127
129  private: void CreateOrthoCam();
130
132  private: void CreateCamera();
133
135  private: virtual void CreateGpuRaysTextures();
136
145  private: Ogre::Matrix4 BuildScaledOrthoMatrix(const float _left,
146  const float _right, const float _bottom, const float _top,
147  const float _near, const float _far);
148
149  private: void UpdateRenderTarget(Ogre::RenderTarget *_target,
150  Ogre::Material *_material,
151  Ogre::Camera *_cam,
152  const bool _updateTex);
153
156  private: virtual double CosHorzFOV() const;
157
160  private: virtual void SetCosHorzFOV(const double _chfov);
161
164  private: virtual double CosVertFOV() const;
165
168  private: virtual void SetCosVertFOV(const double _cvfov);
169
172  private: virtual double HorzHalfAngle() const;
173
176  private: virtual double VertHalfAngle() const;
177
180  private: virtual void SetHorzHalfAngle(const double _angle);
181
184  private: virtual void SetVertHalfAngle(const double _angle);
185
189  private: std::unique_ptr<OgreGpuRaysPrivate> dataPtr;
191
192  private: friend class OgreScene;
193  };
194  }
195  }
196 }
197 #endif
Definition: gz/rendering/base/BaseGpuRays.hh:46
Gpu Rays used to render depth data into an image buffer.
Definition: gz/rendering/ogre/OgreGpuRays.hh:59
virtual common::ConnectionPtr ConnectNewGpuRaysFrame(std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)> _subscriber) override
Pointer to the render target.
Copy to the specified memory direction the gpu rays data.
virtual void notifyRenderSingleObject(Ogre::Renderable *_rend, const Ogre::Pass *_p, const Ogre::AutoParamDataSource *_s, const Ogre::LightList *_ll, bool _supp) override
Preforms any necessary final rendering work. Once rendering is complete the camera will alert any lis...
virtual const float * Data() const override
All things needed to get back z buffer for gpu rays data.
Create dummy render texture. Needed to satisfy inheritance.
Definition: gz/rendering/ogre/OgreScene.hh:41
