gz/rendering/ogre/OgreLidarVisual.hh
16 */
17
18 #ifndef IGNITION_RENDERING_OGRE_OGRELIDARVISUAL_HH_
19 #define IGNITION_RENDERING_OGRE_OGRELIDARVISUAL_HH_
20
21 #include <vector>
22 #include <memory>
27
28 namespace ignition
29 {
30  namespace rendering
31  {
32  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
33  //
34  // Forward declaration
35  class OgreLidarVisualPrivate;
36
38  class IGNITION_RENDERING_OGRE_VISIBLE OgreLidarVisual
39  : public BaseLidarVisual<OgreVisual>
40  {
42  protected: OgreLidarVisual();
43
45  public: virtual ~OgreLidarVisual();
46
47  // Documentation inherited.
48  public: virtual void Init() override;
49
50  // Documentation inherited.
51  public: virtual void PreRender() override;
52
53  // Documentation inherited.
54  public: virtual void Destroy() override;
55
56  // Documentation inherited
57  public: virtual void Update() override;
58
59  // Documentation inherited
60  public: virtual void SetPoints(
61  const std::vector<double> &_points) override;
62
63  // Documentation inherited
64  // This only affects lidar visuals with type LVT_POINTS
65  public: virtual void SetPoints(const std::vector<double> &_points,
67  override;
68
69  // Documentation inherited
70  public: virtual void ClearPoints() override;
71
72  // Documentation inherited
73  public: virtual unsigned int PointCount() const override;
74
75  // Documentation inherited
76  public: virtual std::vector<double> Points() const override;
77
79  private: void Create();
80
82  private: void ClearVisualData();
83
84  // Documentation inherited
85  public: virtual void SetVisible(bool _visible) override;
86
88  private: friend class OgreScene;
89
92  };
93  }
94  }
95 }
96 #endif
Base implementation of a Lidar Visual.
Definition: gz/rendering/base/BaseLidarVisual.hh:37
Ogre implementation of a Lidar Visual.
Definition: gz/rendering/ogre/OgreLidarVisual.hh:40
Update the Visual.
virtual void SetPoints(const std::vector< double > &_points, const std::vector< ignition::math::Color > &_colors) override
Set lidar points to be visualised.
virtual std::vector< double > Points() const override
Get the points in laser data.
virtual void SetPoints(const std::vector< double > &_points) override
Clear the points of the lidar visual.
Get number of points in laser data.
Definition: gz/rendering/ogre/OgreScene.hh:41
