gz/rendering/ogre/OgreMesh.hh
17 #ifndef GZ_RENDERING_OGRE_OGREMESH_HH_
18 #define GZ_RENDERING_OGRE_OGREMESH_HH_
20 #include <map>
21 #include <memory>
22 #include <string>
23 #include <unordered_map>
24 #include <vector>
29
30 namespace Ogre
31 {
32  class Entity;
33  class SubEntity;
34 }
35
36 namespace ignition
37 {
38  namespace rendering
39  {
40  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
41  //
42  // forward declarations
43  class OgreMeshPrivate;
44
45  class IGNITION_RENDERING_OGRE_VISIBLE OgreMesh :
46  public BaseMesh<OgreGeometry>
47  {
49
50  protected: OgreMesh();
51
52  public: virtual ~OgreMesh();
53
54  // Documentation inherited.
55  public: virtual void Destroy() override;
56
57  // Documentation inherited.
58  public: virtual bool HasSkeleton() const override;
59
60  // Documentation inherited.
62  SkeletonLocalTransforms() const override;
63
64  // Documentation inherited.
65  public: virtual void SetSkeletonLocalTransforms(
66  const std::map<std::string, math::Matrix4d> &_tfs) override;
67
68  // Documentation inherited.
70  const override;
71
72  // Documentation inherited.
73  public: virtual void SetSkeletonWeights(
74  const std::unordered_map<std::string, float> &_weights) override;
75
76  // Documentation inherited.
77  public: virtual void SetSkeletonAnimationEnabled(const std::string &_name,
78  bool _enabled, bool _loop = true, float _weight = 1.0) override;
79
80  // Documentation inherited.
81  public: virtual bool SkeletonAnimationEnabled(const std::string &_name)
82  const override;
83
84  // Documentation inherited.
85  public: virtual void UpdateSkeletonAnimation(
86  std::chrono::steady_clock::duration _time) override;
87
88  public: virtual Ogre::MovableObject *OgreObject() const override;
89
90  protected: virtual SubMeshStorePtr SubMeshes() const override;
91
93
94  protected: Ogre::Entity *ogreEntity = nullptr;
95
96  private: friend class OgreScene;
97
98  private: friend class OgreMeshFactory;
99
101  private: std::unique_ptr<OgreMeshPrivate> dataPtr;
102  };
103
104  class IGNITION_RENDERING_OGRE_VISIBLE OgreSubMesh :
105  public BaseSubMesh<OgreObject>
106  {
107  protected: OgreSubMesh();
108
109  public: virtual ~OgreSubMesh();
110
111  public: virtual Ogre::SubEntity *OgreSubEntity() const;
112
113  public: virtual void Destroy() override;
114
115  // Documentation inherited
116  protected: virtual void SetMaterialImpl(MaterialPtr _material) override;
117
118  protected: virtual void Init() override;
119
120  protected: Ogre::SubEntity *ogreSubEntity;
121
122  private: friend class OgreScene;
123
124  private: friend class OgreSubMeshStoreFactory;
125  };
126  }
127  }
128 }
129 #endif
Definition: gz/rendering/base/BaseMesh.hh:39
Definition: gz/rendering/base/BaseMesh.hh:133
Definition: gz/rendering/ogre/OgreMeshFactory.hh:39
Definition: gz/rendering/ogre/OgreMesh.hh:47
virtual Ogre::MovableObject * OgreObject() const override
OgreSubMeshStorePtr subMeshes
Definition: gz/rendering/ogre/OgreMesh.hh:92
virtual std::unordered_map< std::string, float > SkeletonWeights() const override
Get skeleton node weight.
Check whether the mesh has skeleton.
virtual void SetSkeletonLocalTransforms(const std::map< std::string, math::Matrix4d > &_tfs) override
Set transforms for the skeleton.
virtual bool SkeletonAnimationEnabled(const std::string &_name) const override
Get whether a skeleton animation is enabled or not.
virtual void SetSkeletonWeights(const std::unordered_map< std::string, float > &_weights) override
Set skeleton node weight.
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms() const override
Get the skeleton local transforms.
virtual void SetSkeletonAnimationEnabled(const std::string &_name, bool _enabled, bool _loop=true, float _weight=1.0) override
Set whether a skeleton animation should be enabled or not.
virtual void UpdateSkeletonAnimation(std::chrono::steady_clock::duration _time) override
Play the active skeleton animation to the specified time.
Definition: gz/rendering/ogre/OgreScene.hh:41
Definition: gz/rendering/ogre/OgreMeshFactory.hh:71
Definition: gz/rendering/ogre/OgreMesh.hh:106
Engine implementation for setting the material of this SubMesh.
virtual Ogre::SubEntity * OgreSubEntity() const
Ogre::SubEntity * ogreSubEntity
Definition: gz/rendering/ogre/OgreMesh.hh:120
