gz/rendering/ogre/OgreThermalCamera.hh
16 */
17
18 #ifndef GZ_RENDERING_OGRE_OGRETHERMALCAMERA_HH_
19 #define GZ_RENDERING_OGRE_OGRETHERMALCAMERA_HH_
20
21 #ifdef _WIN32
22  // Ensure that Winsock2.h is included before Windows.h, which can get
23  // pulled in by anybody (e.g., Boost).
24  #include <Winsock2.h>
25 #endif
26
27 #include <memory>
28 #include <string>
29
32 #include "gz/rendering/ogre/Export.hh"
39
40 #include "gz/common/Event.hh"
41 #include "gz/common/Console.hh"
42
43
44 namespace Ogre
45 {
46  class Material;
47  class Camera;
48 }
49
50 namespace ignition
51 {
52  namespace rendering
53  {
54  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
55  //
56  // forward declaration
57  class OgreThermalCameraPrivate;
58
63  class IGNITION_RENDERING_OGRE_VISIBLE OgreThermalCamera :
64  public BaseThermalCamera<OgreSensor>
65  {
67  protected: OgreThermalCamera();
68
70  public: virtual ~OgreThermalCamera();
71
73  public: virtual void Init() override;
74
76  public: virtual void CreateRenderTexture();
77
80  protected: void DestroyRenderTexture();
81
83  public: virtual void PostRender() override;
84
88  public: virtual gz::common::ConnectionPtr ConnectNewThermalFrame(
89  std::function<void(const uint16_t *, unsigned int, unsigned int,
90  unsigned int, const std::string &)> _subscriber) override;
91
92  // Documentation inherited.
93  public: virtual void PreRender() override;
94
96  public: virtual void Render() override;
97
98  // Documentation inherited
99  public: virtual void Destroy() override;
100
103  protected: virtual RenderTargetPtr RenderTarget() const override;
104
106  protected: void CreateCamera();
107
109  private: void CreateThermalTexture();
110
112  protected: Ogre::Camera *ogreCamera = nullptr;
113
117
118  private: friend class OgreScene;
119  };
120  }
121  }
122 }
123 #endif
Base implementation of the ThermalCamera class.
Definition: gz/rendering/base/BaseThermalCamera.hh:37
Definition: gz/rendering/ogre/OgreScene.hh:41
Depth camera used to render thermal data into an image buffer.
Definition: gz/rendering/ogre/OgreThermalCamera.hh:65
Destroy render texture created by CreateRenderTexture() Note: It's not virtual.
Get a pointer to the render target.
Render the camera.
void CreateCamera()
Create the camera.
Initialize the camera.
Implementation of the render call.
Create a texture.
virtual gz::common::ConnectionPtr ConnectNewThermalFrame(std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect to the new thermal image signal.
