OgreStorage.hh
17 #ifndef GZ_RENDERING_OGRE_OGRESTORAGE_HH_
18 #define GZ_RENDERING_OGRE_OGRESTORAGE_HH_
20 #include <memory>
22
31
32 namespace gz
33 {
34  namespace rendering
35  {
36  inline namespace GZ_RENDERING_VERSION_NAMESPACE {
37
38 // armhf failed to build with this code. It can not be removed for the rest
39 // of arches to keep ABI but should be removed in major versions unreleased
40 // see https://github.com/gazebosim/gz-rendering/pull/457
41 #ifndef __ARM_PCS_VFP
42  template class BaseSceneStore<OgreScene>;
43  template class BaseNodeStore<OgreNode>;
44  template class BaseLightStore<OgreLight>;
45  template class BaseSensorStore<OgreSensor>;
46  template class BaseVisualStore<OgreVisual>;
47  template class BaseGeometryStore<OgreGeometry>;
48  template class BaseSubMeshStore<OgreSubMesh>;
49  template class BaseMaterialMap<OgreMaterial>;
50 #endif
51
52  typedef BaseSceneStore<OgreScene> OgreSceneStore;
53  typedef BaseNodeStore<OgreNode> OgreNodeStore;
54  typedef BaseLightStore<OgreLight> OgreLightStore;
55  typedef BaseSensorStore<OgreSensor> OgreSensorStore;
56  typedef BaseVisualStore<OgreVisual> OgreVisualStore;
57  typedef BaseGeometryStore<OgreGeometry> OgreGeometryStore;
58  typedef BaseSubMeshStore<OgreSubMesh> OgreSubMeshStore;
59  typedef BaseMaterialMap<OgreMaterial> OgreMaterialMap;
60
69  }
70  }
71 }
72 #endif
