BaseNodeCompositeStore Class Reference
#include <BaseStorage.hh>
- Public Member Functions inherited from BaseCompositeStore< Node >
 BaseCompositeStore ()
virtual ~BaseCompositeStore ()
virtual bool AddStore (TStorePtr _store)
 Add the given store. If the given store already exists, then no work will be done. More...
virtual bool ContainsStore (ConstTStorePtr _store) const
 Determine if given store exists. More...
virtual void DestroyAll ()
virtual TStorePtr GetStore (unsigned int _index) const
 Get store at the given index. If no such store exists NULL will be returned. More...
virtual unsigned int GetStoreCount () const
 Get number of Stores. More...
virtual void RemoveAll ()
virtual TStorePtr RemoveStore (TStorePtr _store)
 Remove given store. If no such store exists no work will be done and NULL will be returned. More...
virtual TStorePtr RemoveStore (unsigned int _index)
 Remove store at the given index. If no such store exists no work will be done and NULL will be returned. More...
virtual TStorePtr RemoveStoreImpl (TStoreIter _iter)
- Public Member Functions inherited from CompositeStore< T >
virtual ~CompositeStore ()=default
virtual ~Store ()=default
- Protected Attributes inherited from BaseCompositeStore< Node >
TStoreList stores
