Gazebo Sensors
AirPressureSensor Class Reference
#include <AirPressureSensor.hh>
 AirPressureSensor ()
 constructor
virtual ~AirPressureSensor ()
 destructor
virtual bool Init () override
double ReferenceAltitude () const
 Get the vertical reference altitude.
void SetReferenceAltitude (double _reference)
 Set the reference altitude.
 Update the sensor.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A sensor that reports air pressure readings.
◆ AirPressureSensor()
constructor
◆ ~AirPressureSensor()
virtual ~AirPressureSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ ReferenceAltitude()
double ReferenceAltitude ( ) const
Verical reference position in meters
◆ SetReferenceAltitude()
void SetReferenceAltitude ( double  _reference)
[in]_referenceVerical reference position in meters
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
