Gazebo Sensors
AirSpeedSensor Class Reference
AirSpeed Sensor Class. More...
#include <AirSpeedSensor.hh>
 AirSpeedSensor ()
 constructor
virtual ~AirSpeedSensor ()
 destructor
virtual bool Init () override
void SetVelocity (const gz::math::Vector3d &_vel)
 Update the velocity of the sensor.
void SetWindVelocity (const gz::math::Vector3d &_windVel)
 Update the wind velocity.
 Update the sensor.
gz::math::Vector3d Velocity () const
 Get the current velocity.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A sensor that reports air speed through differential pressure readings.
◆ AirSpeedSensor()
constructor
◆ ~AirSpeedSensor()
virtual ~AirSpeedSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetVelocity()
void SetVelocity ( const gz::math::Vector3d &  _vel)
◆ SetWindVelocity()
void SetWindVelocity ( const gz::math::Vector3d &  _windVel)
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ Velocity()
gz::math::Vector3d Velocity ( ) const
Current velocity of the sensor.
