Gazebo Sensors
AltimeterSensor Class Reference
#include <AltimeterSensor.hh>
 AltimeterSensor ()
 constructor
virtual ~AltimeterSensor ()
 destructor
virtual bool Init () override
void SetPosition (double _pos)
 Set the current z position of the altimeter.
void SetVerticalReference (double _reference)
 Set the vertical reference position of the altimeter.
void SetVerticalVelocity (double _vel)
 Set the vertical velocity of the altimeter.
 Update the sensor.
double VerticalPosition () const
 Get the vertical position of the altimeter relative to the reference position.
double VerticalReference () const
 Get the vertical reference position of the altimeter.
double VerticalVelocity () const
 Get the vertical velocity of the altimeter.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
An altimeter sensor that reports vertical position and velocity readings over gz transport
◆ AltimeterSensor()
constructor
◆ ~AltimeterSensor()
virtual ~AltimeterSensor ( )
destructor
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetPosition()
void SetPosition ( double  _pos)
[in]_posZ position in meters
◆ SetVerticalReference()
void SetVerticalReference ( double  _reference)
[in]_referenceVerical reference position in meters
◆ SetVerticalVelocity()
void SetVerticalVelocity ( double  _vel)
[in]_velVertical velocity in meters per second
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ VerticalPosition()
double VerticalPosition ( ) const
Vertical position relative to referene position
◆ VerticalReference()
double VerticalReference ( ) const
◆ VerticalVelocity()
double VerticalVelocity ( ) const
