Gazebo Sensors
CpuLidarSensor Class Reference
CPU-based lidar sensor that performs ray casting without depending on gz-rendering. More...
#include <CpuLidarSensor.hh>
struct  RayResult
 Result of a single ray cast. More...
 CpuLidarSensor ()
 constructor
virtual ~CpuLidarSensor ()
 destructor
gz::math::Angle AngleMax () const
 Get the maximum horizontal angle.
gz::math::Angle AngleMin () const
 Get the minimum horizontal angle.
std::vector< std::pair< gz::math::Vector3d, gz::math::Vector3d > > GenerateRays () const
 Generate rays from the lidar configuration.
double RangeMax () const
 Get the maximum range.
double RangeMin () const
 Get the minimum range.
void Ranges (std::vector< double > &_ranges) const
 Get all range values.
unsigned int RayCount () const
 Get the horizontal ray count.
void SetRaycastResults (const std::vector< RayResult > &_results)
 Set the raycast results from the physics engine.
 Update the sensor.
gz::math::Angle VerticalAngleMax () const
 Get the maximum vertical angle.
gz::math::Angle VerticalAngleMin () const
 Get the minimum vertical angle.
unsigned int VerticalRayCount () const
 Get the vertical ray count.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
virtual bool Init ()
 Initialize values in the sensor This will set the next update time to zero. This is particularly useful if simulation time has jumped backward, for example during a seek backward in a log file.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
◆ CpuLidarSensor()
constructor
◆ ~CpuLidarSensor()
virtual ~CpuLidarSensor ( )
destructor
◆ AngleMax()
gz::math::Angle AngleMax ( ) const
◆ AngleMin()
gz::math::Angle AngleMin ( ) const
◆ GenerateRays()
std::vector< std::pair< gz::math::Vector3d, gz::math::Vector3d > > GenerateRays ( ) const
Vector of (start, end) pairs in entity frame
◆ HasConnections()
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
◆ RangeMax()
double RangeMax ( ) const
◆ RangeMin()
double RangeMin ( ) const
◆ Ranges()
void Ranges ( std::vector< double > &  _ranges) const
[out]_rangesVector to fill with range data.
◆ RayCount()
unsigned int RayCount ( ) const
◆ SetRaycastResults()
void SetRaycastResults ( const std::vector< RayResult > &  _results)
[in]_resultsVector of results, one per ray.
◆ Update() [1/3]
[in]_nowThe current time
true if the update was successful
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ VerticalAngleMax()
gz::math::Angle VerticalAngleMax ( ) const
◆ VerticalAngleMin()
gz::math::Angle VerticalAngleMin ( ) const
◆ VerticalRayCount()
unsigned int VerticalRayCount ( ) const
