Gazebo Sensors
ForceTorqueSensor Class Reference
Force Torque Sensor Class. More...
#include <ForceTorqueSensor.hh>
 ForceTorqueSensor ()
 constructor
virtual ~ForceTorqueSensor ()
 destructor
math::Vector3d Force () const
 Get the current joint force.
virtual bool Init () override
const msgs::Wrench & MeasuredWrench () const
 Get the most recent wrench measurement. This matches the data published over the gz-transport topic.
math::Quaterniond RotationChildInSensor () const
 Set the rotation of the joint parent relative to the sensor frame.
math::Quaterniond RotationParentInSensor () const
void SetForce (const math::Vector3d &_force)
 Set the force vector in sensor frame and where the force is applied on the child (parent-to-child)
void SetRotationChildInSensor (const math::Quaterniond &_rotChildInSensor)
 Set the rotation of the joint child relative to the sensor frame.
void SetRotationParentInSensor (const math::Quaterniond &_rotParentInSensor)
void SetTorque (const math::Vector3d &_torque)
 Set the torque vector in sensor frame and where the torque is applied on the child (parent-to-child)
math::Vector3d Torque () const
 Get the current joint torque.
 Update the sensor.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A force-torque Sensor that reports force and torque applied on a joint.
◆ ForceTorqueSensor()
constructor
◆ ~ForceTorqueSensor()
virtual ~ForceTorqueSensor ( )
destructor
◆ Force()
math::Vector3d Force ( ) const
The latest measured force.
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ Load() [1/2]
◆ Load() [2/2]
◆ MeasuredWrench()
const msgs::Wrench & MeasuredWrench ( ) const
The most recent wrench measurement.
◆ RotationChildInSensor()
math::Quaterniond RotationChildInSensor ( ) const
The current rotation the child in the sensor frame.
◆ RotationParentInSensor()
math::Quaterniond RotationParentInSensor ( ) const
The current rotation the parent in the sensor frame.
◆ SetForce()
void SetForce ( const math::Vector3d &  _force)
[in]_forceforce vector in newton.
◆ SetRotationChildInSensor()
void SetRotationChildInSensor ( const math::Quaterniond &  _rotChildInSensor)
[in]_rotChildInSensorRotation of child in sensor frame.
◆ SetRotationParentInSensor()
void SetRotationParentInSensor ( const math::Quaterniond &  _rotParentInSensor)
[in]_rotParentInSensorRotation of parent in sensor frame.
◆ SetTorque()
void SetTorque ( const math::Vector3d &  _torque)
[in]_torquetorque vector in newton.
◆ Torque()
math::Vector3d Torque ( ) const
The latest measured torque.
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
