Gazebo Sensors
ImuSensor Class Reference
Imu Sensor Class. More...
#include <ImuSensor.hh>
 ImuSensor ()
 constructor
virtual ~ImuSensor ()
 destructor
math::Vector3d AngularVelocity () const
 Get the angular velocity of the imu.
math::Vector3d Gravity () const
 Get the gravity vector.
virtual bool Init () override
math::Vector3d LinearAcceleration () const
 Get the linear acceleration of the imu.
math::Quaterniond Orientation () const
 Get the orienation of the imu with respect to reference frame.
bool OrientationEnabled () const
 Get whether or not orientation is enabled.
math::Quaterniond OrientationReference () const
 Get the world orienation reference of the imu.
void SetAngularVelocity (const math::Vector3d &_angularVel)
 Set the angular velocity of the imu.
void SetGravity (const math::Vector3d &_gravity)
 Set the gravity vector.
void SetLinearAcceleration (const math::Vector3d &_linearAcc)
 Set the linear acceleration of the imu.
void SetOrientationEnabled (bool _enabled)
 Set whether to output orientation. Not all imu's generate orientation values as they use filters to produce orientation estimates.
void SetOrientationReference (const math::Quaterniond &_orient)
 Set the orientation reference, i.e. initial imu orientation. Imu orientation data generated will be relative to this reference frame.
void SetWorldFrameOrientation (const math::Quaterniond &_rot, WorldFrameEnumType _relativeTo)
 Specify the rotation offset of the coordinates of the World frame relative to a geo-referenced frame.
 Set the world pose of the imu.
 Update the sensor.
 Get the world pose of the imu.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
Imu Sensor Class.
An imu sensor that reports linear acceleration, angular velocity, and orientation
◆ ImuSensor()
ImuSensor ( )
constructor
◆ ~ImuSensor()
virtual ~ImuSensor ( )
destructor
◆ AngularVelocity()
math::Vector3d AngularVelocity ( ) const
Angular velocity of the imu in body frame, expressed in radians per second.
◆ Gravity()
math::Vector3d Gravity ( ) const
Gravity vectory in meters per second squared.
◆ HasConnections()
Reimplemented from Sensor.
virtual bool Init ( )
True on success
◆ LinearAcceleration()
math::Vector3d LinearAcceleration ( ) const
Linear acceleration of the imu in local frame, expressed in meters per second squared.
◆ Load() [1/2]
◆ Load() [2/2]
◆ Orientation()
math::Quaterniond Orientation ( ) const
Orientation in reference frame. If orientation is not enabled, this will return the last computed orientation before orientation is disabled or identity Quaternion if orientation has never been enabled.
◆ OrientationEnabled()
bool OrientationEnabled ( ) const
True if orientation is enabled, false otherwise.
◆ OrientationReference()
math::Quaterniond OrientationReference ( ) const
Orientation reference in world frame
◆ SetAngularVelocity()
void SetAngularVelocity ( const math::Vector3d &  _angularVel)
[in]_angularVelAngular velocity of the imu in body frame expressed in radians per second
◆ SetGravity()
void SetGravity ( const math::Vector3d &  _gravity)
[in]_gravitygravity vector in meters per second squared.
◆ SetLinearAcceleration()
void SetLinearAcceleration ( const math::Vector3d &  _linearAcc)
[in]_linearAccLinear accceleration of the imu in body frame expressed in meters per second squared.
◆ SetOrientationEnabled()
void SetOrientationEnabled ( bool  _enabled)
[in]_enabledTrue to publish orientation data, false to leave the message field empty.
◆ SetOrientationReference()
void SetOrientationReference ( const math::Quaterniond &  _orient)
[in]_orientReference orientation
◆ SetWorldFrameOrientation()
void SetWorldFrameOrientation ( const math::Quaterniond &  _rot,
[in]_rotrotation offset
[in]_relativeToworld frame orientation, ENU by default
◆ SetWorldPose()
[in]_posePose in world frame
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
◆ WorldPose()
Pose in world frame.
