Gazebo Sensors
LogicalCameraSensor Class Reference
#include <LogicalCameraSensor.hh>
 LogicalCameraSensor ()
 constructor
virtual ~LogicalCameraSensor ()
 destructor
double AspectRatio () const
 Get the aspect ratio, which is the width divided by height of the near or far planes.
double Far () const
 Get the far distance. This is the distance from the frustum's vertex to the farthest plane.
virtual bool HasFrustumConnections () const
 Check if there are any frustum subscribers.
 Check if there are any image subscribers.
gz::math::Angle HorizontalFOV () const
 Get the horizontal field of view. The field of view is the angle between the frustum's vertex and the edges of the near or far plane. This value represents the horizontal angle.
msgs::LogicalCameraImage Image () const
 Get the latest image. An image is an instance of msgs::LogicalCameraImage, which contains a list of detected models.
virtual bool Init () override
double Near () const
 Get the near distance. This is the distance from the frustum's vertex to the closest plane.
void SetModelPoses (std::map< std::string, math::Pose3d > &&_models)
 Set the models currently in the world.
 Update the sensor.
 destructor
bool EnableMetrics () const
 FrameId.
SensorId Id () const
 Get the sensor's ID.
bool IsActive () const
bool IsTriggered () const
 Get name.
 Get the current pose.
sdf::ElementPtr SDF () const
void SetActive (bool _active)
 Set Frame ID of the sensor.
 Set the parent of the sensor.
 Update the sensor.
double UpdateRate () const
 Sensor ()
 constructor
A logical camera reports locations of objects. This camera finds models within the sensor's frustum and publishes information about the models on the sensor's topic.
◆ LogicalCameraSensor()
constructor
◆ ~LogicalCameraSensor()
virtual ~LogicalCameraSensor ( )
destructor
◆ AspectRatio()
double AspectRatio ( ) const
The frustum's aspect ratio.
◆ Far()
double Far ( ) const
Far distance.
◆ HasConnections()
Reimplemented from Sensor.
◆ HasFrustumConnections()
virtual bool HasFrustumConnections ( ) const
True if there are info subscribers, false otherwise
◆ HasImageConnections()
virtual bool HasImageConnections ( ) const
True if there are image subscribers, false otherwise
◆ HorizontalFOV()
gz::math::Angle HorizontalFOV ( ) const
The field of view.
◆ Image()
msgs::LogicalCameraImage Image ( ) const
List of detected models.
virtual bool Init ( )
True on success
◆ Load()
◆ Near()
double Near ( ) const
Near distance.
◆ SetModelPoses()
void SetModelPoses ( std::map< std::string, math::Pose3d > &&  _models)
[in]_modelsA map of model names to their world pose.
◆ Update() [1/3]
[in]_nowThe current time
Implements Sensor.
◆ Update() [2/3]
SetUpdateRate()
Implements Sensor.
◆ Update() [3/3]
const bool  _force
Update the sensor.
Remarks
